Just bought my first Powerstroke, came with CEL and ABS lights lit. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-17-2014, 12:44 PM Thread Starter
Hi everyone, First time powerstroke owner here. I bought a 2007 F250 with the 6.0PS and the Check Engine Light and ABS Lights are on.
There is also some sort of performance device, but I have no idea what it is called and was hoping you guys could help me out. There is a switch on the dash (ON/OFF) that seems to be wired to a solenoid on or near the turbo. When its turned on the powerband for the truck is very different. I think it may have been made by BullyDog, but couldnt find anything like it on their website. Any ideas?
CEL Code is a "Turbo Underboost"
ABS light?
Any help is appreciated.
Thanks
cb750 is offline
post #2 of 11 Old 02-17-2014, 12:52 PM
ZMANN's Avatar
Quoted: 1344 Post(s)
? maybe just a switch for the VGT motor ? is there anykind of module ?
do you have a working speedometer if so the abs is probably one of the two front wheel sensor those are replaceable if need be
We Miss you Ronnie
ZMANN is offline
post #3 of 11 Old 02-17-2014, 02:39 PM Thread Starter
No module that I can see.
Speedo works fine, so it must be the front wheel sensor?
cb750 is offline
post #4 of 11 Old 02-17-2014, 02:49 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Does truck pull right or left when u hit the brakes. ABS could be speed sensor on rear axle housing also.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 11 Old 02-17-2014, 02:50 PM
Is it a smoke switch? Is the wire clipped into the one of the two wires that connect to the turbo?
dobronos is offline
post #6 of 11 Old 02-17-2014, 03:06 PM Thread Starter
I just looked up what a smoke switch was and this seems to be it. Now I just need to figure out how to undo it. Could this be the P0299 Code as well?
cb750 is offline
post #7 of 11 Old 02-18-2014, 01:29 PM Thread Starter
Wouldnt the vehicle speed sensor affect the speedo?
cb750 is offline
post #8 of 11 Old 02-18-2014, 01:43 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Yes, using a "smoke switch" would throw that code. That is the Turbo underboost code..which is exactly what condition that switch gives to get the smoke..
Wouldn't the vehicle speed sensor affect the speedo?
When that goes, yes, you usually get a case of the bouncing speedometer.
Please
You could save the life of a sick child
NYC F-350 is offline
post #9 of 11 Old 02-19-2014, 06:49 AM
You should be able to just clear that code. As long as you don't flip that switch you shouldn't get the code again. -Mike
dobronos is offline
post #10 of 11 Old 02-20-2014, 10:50 PM
andyjman's Avatar
Quoted: 2 Post(s)
You can remove the switch, and hook the 2 wires together and tuck em behind the dash if u don't want the switch anymore, then then ull have a hole in the dash.
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
