No start hpop 0 psi - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-16-2014, 08:35 PM Thread Starter
No start hpop 0 psi
Hey I loaded a tune into my 05 and started it and almost immediately it died with no start at all just cranks. I have the torque app on my phone I'm getting 0 psi when I crank it, the icr goes from 14 to 80 when I try to crank, so is the hpop actually out or is it possibly something else
harryhauler is offline
post #2 of 7 Old 02-17-2014, 09:32 AM
Set it back to stock and then try to start it
Could very well be somthing wrong with the tune.
powerstroken00b is offline
post #3 of 7 Old 02-17-2014, 09:34 AM Thread Starter
I've tried that a few times with no luck
post #4 of 7 Old 02-17-2014, 09:12 PM
Blown F-150's Avatar
Unplug your ICP sensor and try it. It probably doesn't have anything to do with the tune if nothing is changing when you go back to stock.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #5 of 7 Old 02-18-2014, 10:03 AM
mrenn's Avatar
Quoted: 3 Post(s)
Unplug your ICP sensor and crank it over.It will set a default psi to start.There are a variety of things that could be causing this.Check the cheaper fixes first.ICP,IPR.If your screen has a hole in it on the IPR something went through it.STC fitting can also cause this if it hasnt been updated.Lots of videos on youtube regarding this crank no start issue and low oil pressure.Search dieseltechron.He's very informative.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #6 of 7 Old 02-18-2014, 01:53 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
Air test the HPO system and listen for the leak. Juggernaut has a great video of the proper test procedure. I'm betting STC fitting since it's an 05 and has no HPO pressure, but it could be standpipes and/or dummy plugs.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #7 of 7 Old 02-18-2014, 03:29 PM
duck fan's Avatar
I built an ICP leak tester for about $25. Best money I ever spent. Saved us days of chasing our tails on my step-son's 05.
I got a 1/4NPT female to M12/1.5 metric adapter at the local Parker store and then a length of airhose with a 1/4NPT on one end to a quick connect on the other. Pressurize with about 100psi and listen for leaks. You will hear the slightest (and I mean slightest) leak at the IPR. That's normal. Any others and you have found where to check.
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
