need 2 be schooled
Could someone please tell me what this means and what I need to do to fix it? It's the only code I have!
Thanks!P0263 Cylinder 1 Contribution/Balance |
Sounds like an injector to me...
It means that the cylinder 1 injector is not working or not workign correctly. You'll also want to check the compression on the cylinder.
definitely flux capacitor. I would change your molecular reconstructer and tune your ion monitor using the wave technique.
![]() I would check cylinder compression and go from there |
I cleared it and changed my ion tuner back to STOCK and now I don't have the P0263 code anymore, but now I have a P0606 code now..........My nuclear rocket launcher is about to be installed!!!! What the crude is P0606?
P0606-internal pcm failure
This is with the superchips? Seems like I have heard of a lot of PCM problems with super chips.
6.0
need to take that chip out and then put scanner on it.did you check your plugs.on pcm and idm?
