CAC boot clamps - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 12 Old 02-14-2014, 02:41 PM Thread Starter
CAC boot clamps
Torque specs for CAC tube/boot clamps? Ford F350 Diesel 6.0
Do they even need to be torqued on? Or just hand tighten to the max?
Thank you
ssaige3 is offline
post #2 of 12 Old 02-14-2014, 02:51 PM
john galt's Avatar
Quoted: 1403 Post(s)
from my limited understanding. just torque the crap out of em without breaking them.
I think I remember reading that riff raff not only make a great boot but a better clamp...I could be wrong about that but...
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #3 of 12 Old 02-14-2014, 03:07 PM
ZMANN's Avatar
Quoted: 1792 Post(s)
i just tighten them down I could find the spec but I never bother i think they may have a stop on them anyway also note the clamp location marks on the hose
Riff Raff may make better ones but OEM has lasted 100,000 miles and my boost is just over 32 psi
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #4 of 12 Old 02-14-2014, 03:09 PM
ZMANN's Avatar
12Nm or 9lb-ft or 105lb-in
john galt likes this.
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 12 Old 02-14-2014, 05:12 PM
midnite rider's Avatar
Quoted: 285 Post(s)
This may sound stupid but clean them good plus IC pipes, then if you married steal the wives hair spray. Spray it on the hoses, then tighten them down. Works great.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 12 Old 02-15-2014, 02:51 PM Thread Starter
Thank you all for all the Info, at least I know what to do now.
ssaige3 is offline
post #7 of 12 Old 10-08-2016, 02:12 PM
fetorino's Avatar
Quoted: 9 Post(s)
Thanks for answering the original posters question
04 F450
Studded 6.0 PSD backed by a Torqueshift
Dually Flatbed gooseneck hauler
BPD 7.3 fan clutch adapter
Sinister Bypass and coolant filters
Blue spring upgrade
Rotella T6
Ford Gold coolant
Magnaflow 4" downpipe FTE 4"in 5" out resonator to stack
FICM fixer rebuild and stock reflash
PHP 25hp heavy tow PCM flash
fetorino is offline
post #8 of 12 Old 10-08-2016, 02:47 PM
ZMANN's Avatar
over two years ago?
your welcome ;-)
were you using the search engine ?
you doing some CAC work ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #9 of 12 Old 10-08-2016, 08:59 PM
fetorino's Avatar
Quoted: 9 Post(s)
over two years ago?
your welcome ;-)
Yes
I was searching for the Torque spec since I had my CAC tubes off.
My truck has a weird hot side tube because it had a PTO. I was going to swap it back to a stock tube but the AC lines have been bent to clear the oddball tube and were in the way.
ZMANN likes this.
04 F450
Blue spring upgrade
Rotella T6
Ford Gold coolant
fetorino is offline
post #10 of 12 Old 10-09-2016, 04:34 PM
ZMANN's Avatar
the PTO is on the transmission
I never heard of a different CAC for any thing other than the dual alt units ??
does your truck run a PTO winch or plow or something ??
FYI 9 ft lbs is tighter than you think if your just doing it by feel at least IMO
i put a torque wrench on mine after i blew a turbo boot ( had them apart a zillion times before no issues )
and they were all a few full turns loose
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
