2004 6.0 No heat and overheats - Ford Powerstroke Diesel Forum
post #1 of 22 Old 02-14-2014, 12:09 PM Thread Starter
I have read a ton of posts about this but none seem to fit exactly what mine is doing and i am relatively new to the 6.0. At idle the truck has no heat,as soon as you accelerate heater blows hot instantly.I pull a boat that weighs approx 3500lbs.When pulling up an incline it will do fine until about the time the aux fan kicks on.The eng temp is at normal and will spike to hot in a couple of seconds with the overheat light coming on.I let off the gas and pull over and it will go back to normal temp in a few seconds.It only does this when pulling uphill,on flat ground it hauls with no problems.
I have deleted the egr,replaced thermostat,oil cooler,degas cap,flushed system and i have no coolant loss.The truck does have a banks six gun which i turn down to 1 when pulling,it also has exhaust and air intake.
Any ideas or help would be greatly appreciated thanks.
200460 is offline
post #2 of 22 Old 02-14-2014, 12:22 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Waterpump.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 22 Old 02-14-2014, 12:35 PM
ZMANN's Avatar
Quoted: 1651 Post(s)
Hmm I had to think about that and reread the op's info
but your right it sounds like it may be a lack of circulation
We Miss you Ronnie
ZMANN is offline
post #4 of 22 Old 02-14-2014, 12:48 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Is it possible the belt tensioner is going, causing belt to slip. ???
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 22 Old 02-14-2014, 01:57 PM Thread Starter
Thanks for the fast responses guys.Since i have had this issue i have replaced the oil cooler and had no change.Could it have blockage elsewhere or just in the cooler itelf?I think i am leaning toward replacing the water pump since it sounds like they have an impeller problem?Sounds like the bulletproof pump is the best way to go?thanks
200460 is offline
post #6 of 22 Old 02-14-2014, 02:21 PM
ZMANN's Avatar
I just got done dealing with an oil cooler
my oil cooler was plugged on the coolant side and the only affect I had was the oil temps 135*
ECT and heater were fine 190*
you will know right away if your water pump impeller is to blame upon removal the BPD pump is nice but other than the billet impeller and quality bearings it really offers no advantages
other than it can be rebuilt
We Miss you Ronnie
ZMANN is offline
post #7 of 22 Old 02-14-2014, 02:26 PM
NYC F-350's Avatar
Quoted: 51 Post(s)
The stock waterpump has a plastic impeller. The Bulletproof is a billet impeller.
Guess which one I have under the hood of my truck......
Please
post #8 of 22 Old 02-17-2014, 08:13 PM
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Just realized that my truck too is not putting out heat at idle but as soon as I accelerate it blows heat. No overheating problem and deltas stay within 10*. Interested to see what you find.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #9 of 22 Old 02-17-2014, 08:22 PM
andyjman's Avatar
Quoted: 2 Post(s)
I vote for water pump too. I just put a bpd water pump on my truck. Beautiful piece of equipment..
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #10 of 22 Old 02-18-2014, 07:23 PM
No heat at idle causes are water pump as stated, low coolant level, thermostat, head gasket.
Powerhouse9228 is offline
