06 erratic speedo - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-12-2014, 05:43 PM Thread Starter
Quoted: 2 Post(s)
06 erratic speedo
I have an 06 king ranch I've owned for about 8 months now and the past couple of months my speedometer has been very erratic, when it first started it completely stopped working for about 2 weeks and one day I got in it and what do ya know its working again, well when iFirst get in the truck it works fine now but after about 20 mins of driving it will start to bounce and eventually stop working completely again until I let it sit over night, I plan on taking the speed sensor out at the end of the week and cleaning it but I was also curious as to what fuse is the vss fuse I could not seem to find it anywhere in the manual, I'll be making a 22 hour trip at the end of the week and don't really want to have to deal with reduced power and possibly tickets cause I can't see how fast I'm going
dslpwr06 is offline
post #2 of 7 Old 02-12-2014, 05:52 PM
Heavy_GD's Avatar
Quoted: 1741 Post(s)
Feedback Score: 3 reviews
if the ABS light isnt on then I doubt its the sensor.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #3 of 7 Old 02-12-2014, 07:05 PM Thread Starter
Quoted: 2 Post(s)
No abs light at all just get the p0500 code for the speed sensor circuit fault, I erase it and still nothing
dslpwr06 is offline
post #4 of 7 Old 02-16-2014, 06:42 AM
Country Mav's Avatar
Quoted: 2 Post(s)
Mine has done similar things did 2 years in cold weather. I've never been able to figure it out!
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #5 of 7 Old 02-17-2014, 12:59 PM Thread Starter
Quoted: 2 Post(s)
Well its cold here but that is not why its doing this, also another side affect is the 4x4 stops working and if I continue to drive the truck with the speedometer like this it will not start working again until the truck is allowed to sit a while, and over the past couple days it has only been lasting about 2 miles and quits, does nobody know where this fuse is or what??
dslpwr06 is offline
post #6 of 7 Old 02-28-2014, 06:26 PM
Blwnmstgt1990's Avatar
My 06 had problems with the speedo as well in cold weather. Mine would hang up at different speeds and not come back to 0 until you cycled the truck on and off with long lead times between. I checked and cleaned the abs sensors and checked every fuse I could think of. Finally took it to Ford and they said I had to replace the whole cluster, instead I sent it circuitboardmedics.com and they rebuilt the cluster with new stepper motors and have never had a problem out of it since. The rebuild was 150 or so if I remember. Just my .02 so take it for what it's worth.
06 CCLB 8"Superlift, Traction bars, Studded, Gogo Diesel DD solenoid, Snow Performance Stg3 Max Mpg, Dicad egr delete, 5" Diamond Eye full straight pipe, AFE Stg2 SI, Banks High-Ram, Billet Powermax, 6.4 banjo bolts, Edge CS Insight, WPE Tuned, PHP Hercules, high idle mod, blue spring, Performance Machine coolant filter.
90 Mustang GT- blown, stroked, and juiced (project)
y2K Busa- 1397 built 60hp wet shot.
Mkiv VW wagon- 350 fwhp (dd)
Blwnmstgt1990 is offline
post #7 of 7 Old 02-28-2014, 06:36 PM Thread Starter
Quoted: 2 Post(s)
Well I figured out what the problem was, I was on my 1300 mile trip and towing a trailer and finally got tired of it being in limp mode, I was doing some research and someone on another forum had said something about the wire on the back of the cluster coming unplugged, ( mind you this was after the $85 speed sensor ) I proceeded to pull out the CD player in a gas station parking lot and started bending the tabs in to pull it out and my speedo started jumping everywhere, needless to say it was a short and it is fixed now
dslpwr06 is offline
