07 6.0 no start please help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-12-2014, 02:06 PM Thread Starter
hey hows it going i have a 2007 ford f250 it started having hot start problems for about a week until one day it turned into a no start after days of searching all these forums i found out it could be dummy plugs went to ford got the part finally had time to do it and the passenger side plug was shot put new ones in and she started right up and ran fine drove it for about and hour or so came home shut it off and now it wont start at all found out when i did my oil change the day before it broke down the first time i seen the filter i got was shorter then the last one went out and bought a new filter and she still wont start one thing i notice was before i wasnt getting a reading on my oil gauge while cranking now that i put the new filter in i get a reading but just no start any help would be appreciative i dont understand how it ran fine after the new dummy plugs but now it wont start
6ohlariat07 is offline
post #2 of 8 Old 02-12-2014, 02:56 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
What about the stand-pipes or STC fitting? You probably need to do an air test, but using a monitor first is the smart choice.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 8 Old 02-12-2014, 03:45 PM Thread Starter
i replaced the stand pipes too i mean it ran perfectly fine after i replaced them as of now i dont have a scanner but im in the mists of buying a scan gauge
post #4 of 8 Old 02-12-2014, 09:14 PM
anschutz1913's Avatar
Quoted: 46 Post(s)
You are having a high pressure oil leak somewhere. Or your HPOP took a crap. Try unplugging your icp sensor and see if it will start.
Sent from AutoGuide.com App
-Tom
2003 F350 CCSB Lariat. 316K. Everything but the studs.
Originally Posted by Justin M View Post
I really think the previous owner should be kicked in the crotch by a buffalo
anschutz1913 is offline
post #5 of 8 Old 02-13-2014, 07:35 AM Thread Starter
I tried unplugging it and it still didn't start I'm leaning towards the ipr I hope it's not a pump or I'm gonna have to work the corner to come with 1000 bucks for it
post #6 of 8 Old 02-13-2014, 08:03 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
Frank got it right. Monitor and air test the HPO system. Most likely it's the STC fitting on the HPOP itself. These pumps very rarely fail. Fitting is a $60 fix.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #7 of 8 Old 02-13-2014, 10:30 AM
Blown F-150's Avatar
+1, My buddy just did his Stand-pipes and Dummy plugs and it lasted about a week before the STC fitting let go. I guess it was just the next weakest link in the system.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #8 of 8 Old 02-15-2014, 05:28 PM
I have my IPR valve out... truck cranks but no start .... i can blow threw the IPR with out it plugged in but pluck it in and key in on position i cant blow threw it... Do that mean its working? Can anyone help thanks
SPD_Hauling is offline
