Starts and dies cold - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-10-2014, 10:29 AM Thread Starter
downfour's Avatar
Ok having a few issues. When it is cold out (0-20) my truck will crank forever and then fire. Black and white smoke pouring out. It will stay at and idle for a few seconds and then just die. It will crank forever fire up and do the same. Probably will do this 3-4 times until it will stay running. If I leave the truck plugged in it's fine. Starts up and runs fine!
Little about the truck. Just under 20k on new long block, rebuilt injectors, icp, ipr, hpop, and rebuilt turbo. Truck has always started fine without plugging in until recently.
I am due for an oil change, has 15-40 rotella in it. I plan on changing to t6. Filters were changed late last summer. Always have the lonney wild on it.
When the long cranks happen it does take a little bit till the oil pressure gauge moves up as well. Any help is appreciated.
Sent from AutoGuide.com App
03 f-350 4x4 lariat dually 6.0
studded and deleted
6 inch miters- for sale or trade for 5 inch single
ccv mod 05-07 grill
pillar gauges
more to come
downfour is offline
post #2 of 4 Old 02-10-2014, 10:42 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Switch it to the T6 like planned and also check your FICM voltage. 15w-40 oil is hard to get moving when it's that cold.
dhanna6powerstroke is offline
post #3 of 4 Old 02-10-2014, 11:02 AM Thread Starter
downfour's Avatar
Well what's gets me is that it has always started fine. All last winter I never plugged it in would start right up and idle just fine.
Some more info I left out.
No codes, deleted,and studded. Other then that truck is stock.
studded and deleted
ccv mod 05-07 grill
pillar gauges
more to come
downfour is offline
post #4 of 4 Old 02-10-2014, 11:03 AM Thread Starter
downfour's Avatar
I will check ficm this weekend when I get a chance! Was already planning to do that but left my multi-meter at home. I work out of state.
studded and deleted
ccv mod 05-07 grill
pillar gauges
more to come
downfour is offline
