Fan clutch, force code? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-08-2014, 02:03 PM Thread Starter
yamasaki's Avatar
Can I force the truck to throw a fan clutch code by unplugging it?
I just put in a new fan clutch this morning and it's in the upper 80's here and I can't hear the fan coming on. Ect temps have crept up into 200 driving around today
I've tried a little spirited driving, idling for long periods, ac on max, etc
From what I've read this fan is supposed to be really loud when it comes on right ? I don't think ive ever heard it
2007 6.0 CC FX4 Lariat
Insight CTS, SCT 3015, EGR Delete, 4" TB Exhaust w/hollowed cat, ARP studs, OEM HG, Coolant Filter, BPD Water Pump, K&N CAI, King Ranch interior, Pioneer AVIC x910bt, Nitto Terra Grapplers
yamasaki is offline
post #2 of 14 Old 02-08-2014, 02:09 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
You'll know it when it comes on but I don't think it's designed to come on until 215 or 225. I've heard mine once in 7 years and I was towing when it did it.
dhanna6powerstroke is offline
post #3 of 14 Old 02-08-2014, 02:31 PM
You should get a code but not a light necessarily. While unplugged test for voltage comeing to it. No voltage with koeo check your fuzes and relay.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 14 Old 02-08-2014, 02:33 PM Thread Starter
yamasaki's Avatar
I unplugged it and started it up and read a p04080
One other thing I noticed is the small line going from the block into the degas is constantly pouring coolant in. Is this normal operation?
yamasaki is offline
post #5 of 14 Old 02-08-2014, 02:34 PM Thread Starter
yamasaki's Avatar
10-4
Trying to figure out why my truck runs so hot .. Doesn't seem right
yamasaki is offline
post #6 of 14 Old 02-08-2014, 02:41 PM Thread Starter
yamasaki's Avatar
Doing some googling and my fog lights don't work.. Was one of the things I've been meaning to get around to
Gotta find a wiring diagram .. Someone mentioned that may also be the same fuse that controls the fan?
yamasaki is offline
post #7 of 14 Old 02-08-2014, 02:54 PM
shughey00's Avatar
Quoted: 35 Post(s)
Hmmm.was reading this and I have a fan code and did not see any wiring issue and...my fog lights don't work either. Was trying to work on this this week but temps to cold outside. Will have to see about the fuse also.
shughey00 is offline
post #8 of 14 Old 02-08-2014, 02:57 PM Thread Starter
yamasaki's Avatar
If its your fan clutch don't buy a new one right away .. I'll send u the one I pulled out today some can test swap if u want
If it turns out to be something else I just put in a new fan clutch for no reason lol
Found this
http://ww2.justanswer.com/uploads/s4..._fan_tests.pdf
yamasaki is offline
post #9 of 14 Old 02-08-2014, 02:58 PM
Check that they are actually plugged in. We found a few in the fleet with factory fog lamps that they had never been plugged in.
post #10 of 14 Old 02-08-2014, 03:02 PM
shughey00's Avatar
Quoted: 35 Post(s)
Plugged in where....I assume you mean not the actual bulbs themselves...if so then yes they are plugged in as I replaced both bulbs. The prevous owner had a plow installed I think and so removed the bulbs and put in some plow lights in the grill.
If you mean plugged in somewhere else.....?
