hot crank no start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-08-2014, 02:45 AM Thread Starter
Exclamation hot crank no start
I drove my truck home from work and wen I got home I turned it off and came back like 15 minutes later and tried to start it. It has a consistent crank but no start. I heard fuel pump come on when I turned the switch on. I tried to start it a few times. I got tired and let it sit for 15-20 minutes and it started with no problem. I was on youtube and they was sayin to pull the cap off fuel filter housing on the engine to check and see if there was fuel in there. I did that and there was fuel inside there. So im lost now. I kno very little about diesels but if I someone can give me a starting point to look for so I can youtube it. I would b grateful. Wat could cause this and wats a price estimate on repair.
1st ford is offline
post #2 of 6 Old 02-08-2014, 03:04 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 498 Post(s)
Sounds like a high pressure oil leak. Diagnostic and repair varies depending on your problem.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is online now
post #3 of 6 Old 02-08-2014, 03:08 AM Thread Starter
Oh ok.. I did look underneath the truck and seen some oil
1st ford is offline
post #4 of 6 Old 02-08-2014, 04:55 AM
LoxDiesel's Avatar
Quoted: 498 Post(s)
High pressure is internal. Every 6.0 I've seen leaks a lil oil. Could be an injector oring. Oil stand pipes, dummy plugs. It could be many things in the high pressure system. Unfortunately to diagnose you need a scan tool that shows live data.
@loxdce
post #5 of 6 Old 02-10-2014, 06:43 AM
Look up DieselTechRon on youtube, he has some good videos that might help you figure out your issue, but having at least the scan gauge would help out a bunch. good luck
BP-1 is offline
post #6 of 6 Old 02-10-2014, 01:02 PM
Quoted: 11 Post(s)
STC fitting. .....I had the same issue
mike01844 is offline
