Check for a bad injector? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-07-2014, 11:40 AM Thread Starter
Quoted: 3 Post(s)
Is there a way to check for a bad injector? I was sitting at a stoplight and my truck started spitting and sputtering and then just died, now it sputters all the way home?
[color=gray]Sent from AutoGuide.com Free App[
mySIXOisSick is offline
post #2 of 6 Old 02-07-2014, 11:41 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
yes there is , a cylinder contribution test would verify which cylinder the skip is on
ITS STOCK
SCUFFY828 is offline
post #3 of 6 Old 02-07-2014, 11:43 AM Thread Starter
Quoted: 3 Post(s)
How do you do that?
post #4 of 6 Old 02-07-2014, 12:14 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
a scanner that has functional tests , reads data , etc, , need to pull codes , need to run a injector buzz test and also cylinder contribution test , it may not be injector , could be electrical issue to injector , a buzz test would help determine that , like I say , need to get a good scanner on the truck to see what your issue is
ITS STOCK
post #5 of 6 Old 02-07-2014, 12:50 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
If you don't have any codes, you pretty much need to have an auto engenuity scanner or Ford IDS system to to an injector buzz test/ cylinder contribution test.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #6 of 6 Old 02-07-2014, 12:55 PM Thread Starter
Quoted: 3 Post(s)
I pulled up the autoenginuity thing and it tuns 250, does that come pre programmed? Like just plug it up and it scans? Does ford run these tests? Im sure they do but not for cheap
