Dump Body Electrical Wire shorted, now Crank No Start issue. Pls help! - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-07-2014, 05:38 AM Thread Starter
2006 F350 6.0 Dump Body Stock except for KN Intake...
HERES THE STORY:
I was out plowing the other night and i put the truck in reverse, pressed the lift button on my fishstick and BANG. I hear a loud bang under my feet and my truck instantly shuts off. I put it back in park, try to restart it and it CRANKS NO START.
I get out of the truck and see that the electrical cable that runs from the battery to the solenoid (i believe this is what it is) for the dump controller/body is hanging and laying in the snow. This is what i heard POP/BANG. I got a new terminal and hooked the cable back onto the solenoid. The cable was horribly corroded, as you can see in the left cable in the pictures. (the right side going to the cab is where it came off). Once i got it hooked back up i tried starting again it it cranked no start again.
Closeup Photo by surfmotion1 | Photobucket
Far Photo by surfmotion1 | Photobucket
I then checked all the fuses and I replaced the IDM Relay #304. Still crank no start.
As i'm checking the fuse box under the hood i notice that my Degas/Coolant Resevoir is BONE DRY. I had noticed that truck's motor blower/fan (i believe thats what its called), was blowing/"whooshing" really hard when i really gunned the truck. It was so loud at times that i could barely hear the turbo spooling. I don't know if this issue is related to the Crank no start, or just a whole other story... It was making this noise for 6-8 hours. Hadn't really heard excessive motor blower/fan "whooshing" prior to this event. Here are pictures of the Degas, there was minimal white residue on the cap/reservoir or anywhere else i could see in that area of the engine bay, but it looked like it was definitely spewing out the cap a little...
photo_2copy_zps2aa6c824.jpg Photo by surfmotion1 | Photobucket
photo_1copy_zps8748d057.jpg Photo by surfmotion1 | Photobucket
At this point, I called for a tow and I had it towed to my local mechanic (a guy i went to high school with) who knows diesels but doesn't work on them everyday. He has the ford scan tool and it read 3 codes for FICM and a couple other Power Codes.
My questions are:
-when the dump body wire shorted out, could that fry the FICM? or is there something else that caused the wire to short which in turn fried the FICM?
-if the Degas is bone dry, is it possible that it is just an EGR issue and hasn't reached the Head Gaskets? or is it a high probability that the issue went straight to the HG's?
-has anyone ever ordered a rebuilt FICM from Rudy's Diesel in NC? he's on ebay.
In general, i just want to know if you guys have any insight/ideas on what my issues could be. also, i read somewhere that issues like this Need to be checked out by a certified diesel tech. this buddy of mine would never get into anything on my truck without being 100% positive he could fix it properly.
as of now, I'm going to order the FICM from Rudy's and my mech is going to install it when it comes in. Then we will (hopefully) get the truck started and go to the Coolant issue from there.
i am sorry for the long post. this is my first diesel and am learning as i go. i am obviously stressed and wanted to write this all down on the forum for any and all insight you guys have. thank you for reading and thank you in advance for any input.
MATT
surfmotion is offline
Tags
crank no start , degas , egr , head gaskets 6.0 , wire short
