Whats is this weird noise??? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-06-2014, 06:27 PM Thread Starter
This noise just started happening when the temperature started getting colder here in ohio. Temps are between 0 - 40 F. When injectors are buzzing there is this loud whining sound coming from what seems the top fuel bowl. No problem at all starting, just a weird noise I've never heard before.. Any idea?? I have a video of the noise.. - Mike
dobronos is offline
post #2 of 15 Old 02-10-2014, 02:47 PM Thread Starter
no one has any idea????
dobronos is offline
post #3 of 15 Old 02-10-2014, 02:51 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
No idea. Bump this up. Is it running or just the key on the run position?
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 15 Old 02-10-2014, 05:44 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Is that your vacum pump,thats wierd.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 15 Old 02-10-2014, 06:11 PM
brscott38's Avatar
I think thats a midget screaming because he wants out
brscott38 is offline
post #6 of 15 Old 02-10-2014, 07:50 PM Thread Starter
This is key on engine off. It makes this sound when the injectors are buzzing. The noise is coming from where the top fuel bowl is..
dobronos is offline
post #7 of 15 Old 02-10-2014, 10:37 PM
That sounds like either bad ficm or glow plug relay actuator I would check both
Anigrelli132 is offline
post #8 of 15 Old 02-11-2014, 06:37 AM Thread Starter
ficm is at 48 volts. and i never have a problem starting truck? truck always starts right up even when not plugged in..
dobronos is offline
post #9 of 15 Old 02-11-2014, 09:47 AM
any thrown codes? does it go away when wait to start light goes off? is it only up till you start the truck or is it consistent even when running?
post #10 of 15 Old 02-11-2014, 09:57 AM
Could the fuel pressure regulator cause a noise like that? Have you done a blue spring update? My fuel pressure regulator makes some noise while it is filling but nothing like that. I'm not sure how the fuel pressure regulator works but maybe something is in the regulator it self. Idk?
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
