help please, coolant disappearing, then reappearing. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-06-2014, 07:00 AM Thread Starter
So super weird thing happening with my coolant levels lately.
it all started (or at least i noticed this yesterday) while climbing a hill doing 120km/hr heat on full blast. all of a sudden my vents started to blow cold air at me. my first reaction was to check the coolant levels. so i pulled over and checked the degas bottle, it was bone dry. fearing id either blown a head gasket or EGR cooler, I brought the truck strait home. popped the hood and walked away. came back in 10 minutes and the coolant level was right back at normal in the bottle... unscrewed the cap and it filled up even more.
i idled the truck for 15 mins and the coolant never dropped. then today when i went for a drive again, the same thing happened, all coolant disappeared from the tank, i unscrewed the cap and it filled back up.
some technical info that may or may not help
i monitor my ECT and EOT temps and they normally stay between 6-10 degrees apart. they will however hit 15 on occasion when say im cruising at a low speed. however i have never seen ECT over 190, and its always the lower number of the two.
ive replaced my stock degas cap with one from NAPA
air temperature is about -25 Celsius at the moment (making it impossible to tell if my exhaust is blowing white smoke or not)
I am running stock ford gold coolant
197 thousand km's
any idea or help would be greatly appreciated
20066.0 is offline
post #2 of 3 Old 02-06-2014, 03:21 PM
Wheres the coolant level in the mornings or before you drive it?
2006 F250 Lariat Bulletproofed
2006 F350 XLT bulletproofed SOLD
1983 Mustang GT 410/C4 SOLD
MustangSmitty is online now
post #3 of 3 Old 02-06-2014, 04:13 PM
This is useually a case of expansion and contraction brought about by temperature change.
Now this happens all the time in the coolant system the difference this time is your coolant level is right on the curve [slightly low] to the extent that the expansion and contraction is really noticeable.
Example: When it gets cold it shrinks inwards lowering the level out of sight when it expands you can see it. A byproduct is an increse in pressure which further pushes the level down until the force of expansion overcomes the force of pressure.
When you suddenly release the force of pressure holding the coolant down the force of expansion pushes the coolant outward.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
