Problems.... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-05-2014, 03:19 PM Thread Starter
Problems....
I have a 05 f250 with the 6.0 with 165k. I was leaving work today and about 8 miles after I left work I lost 5th and like it slipped and then dropped to 4th then same with 3rd and had 2nd for a little wile then lost everything. I stopped on the side of the road and tried reverse and it would take reverse but would not rev up at all but would rev in the other gears. I shut the truck off waited a little wile then restarted the truck and it ran and drove fine.
I get 15 miles down the road I came up to my turn and it just died. I tried starting it and it started like normal then died again. Then the battery's were dead. Before the turn my cts monitor said I had 14.0 volts
The only transmission problem I had was a slip from 3rd to 4th and that was only sometimes.
Cntryby95 is offline
post #2 of 3 Old 02-05-2014, 03:25 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Take that alternator and have it tested. Low voltage will cause crazy things. Also, if one battery checks bad, replace both of them.
dhanna6powerstroke is offline
post #3 of 3 Old 02-05-2014, 05:09 PM Thread Starter
I put a new alternator in about 3 weeks ago. Batterys were new in April but I was going to have them tested this weekend because I think one of them is weak.
