Electrical Problem ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-04-2014, 05:01 PM Thread Starter
hey guys I need some help. My 04 6.0 L battery lite came on today. when i got to work the ABS light came on . had 12.1 volts on each battery. cleaned the terminals ( there was a little corrosion) when i tried to start it just clicked. finally got it started back up. after 10 minutes the instrument cluster went dead then the truck died. any ideas??? nothing at all works.
dougggie is offline
post #2 of 6 Old 02-04-2014, 05:41 PM
Quoted: 3 Post(s)
your alternator may have died, mine did the same thing.
2014 f350 ccsb 4x4 Platinum Sunday driver occasional hauler
2004 f350 cclb 4x4 fully bulletproofed fx4 work truck
2009 f350 kr cclb lifted 8 inches on 37s, h and s mini maxx, afe 4inch downpipe back with muffler, and 6 inch tip. thanks to Rudy's diesel!
SOLD, BOY DO I MISS IT!
bottomland4x4 is offline
The Following User Says Thank You to bottomland4x4 For This Useful Post:
dougggie (02-05-2014)
post #3 of 6 Old 02-04-2014, 11:13 PM
You need to seperate the batteries and load test them individualy. You may have enough volts but not enough amps available.
Also you cleaned the wires but did you also clean the grounds. You may not be completeing circuit.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
The Following User Says Thank You to dannyboy950 For This Useful Post:
post #4 of 6 Old 02-05-2014, 05:18 AM Thread Starter
Thanks but It is a new, (less than 1 1/2 yr ) alt
dougggie is offline
post #5 of 6 Old 02-05-2014, 05:19 AM Thread Starter
thanks but it is less than 1 1/2 year old...
dougggie is offline
post #6 of 6 Old 02-06-2014, 05:40 AM
ATV PRO 11's Avatar
Sounds like your running off the batteries.
Even an alt 1 1/2 yr old can go bad.
When its running have you tried checking voltage alt is charging at?
Needs to be a min of 13.6. Anything lower and these electronics just dont like it.
And again, get batteries load tested. Bad alt can eat up a good set of batteries.
I've read somewhere too that if the voltage isn't at a minumum number, the computer won't trigger truck to fire. But can't remember where I read it.
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
