Question about cold start smoke - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-04-2014, 02:17 PM Thread Starter
Quoted: 2 Post(s)
I've noticed that the past few times I've started my truck after sitting more than 24 hours, it smokes white/greyish smoke at first. If I burp the throttle, it goes to black (Looney Tune) but immediately turns white/greyish again. EGR is deleted, and the truck isn't puking a bit, just barely over 100 miles on a fresh set of OEM head gaskets and studs. The only concern I have is when I installed the injectors, I just torqued them down to 31 ft/lbs and didn't 'tap' them in place like some do. The injectors are the original ones that came out, but I did put new o-rings and copper washers on each one.
Once the truck warms up, the smoke does go away. So maybe it's normal?
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #2 of 11 Old 02-05-2014, 03:37 PM
Quoted: 10 Post(s)
How cold out is it where you are
mike01844 is offline
post #3 of 11 Old 02-05-2014, 04:22 PM Thread Starter
Quoted: 2 Post(s)
In the 40s
---Garret
S&B Intake
Studded and deleted
CTS w/EGT
post #4 of 11 Old 02-05-2014, 04:34 PM
You may have one or more injectors with the dribbles. excess fuel and when it finally burns off it quits smokeing.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 11 Old 02-05-2014, 11:30 PM Thread Starter
Quoted: 2 Post(s)
That's what my gut says, but I don't have any hard evidence to go on at the moment. No codes, and the smoke doesn't really reek of diesel fuel. It smells like diesel, but more like exhaust if that makes sense.
Today I started the truck to move it, and it ran fine, smoked a little of course. (Temps hit a high of 42 today). Tried to start the ol 7.3 to take it to work, and it had dead batteries. So I got back in the 6.0 and started it, and it ran rough, like a multiple cyl. misfire and was puffing out stormcloud-grey (dark grey) smoke, in rythm with the misfire. I shut the truck off, checked for anything obvious (loose ficm connector, leaks, etc), didn't find anything, so I restarted the truck and it ran perfectly normal. Drove it home tonight and she still ran great. Not sure what to think of the random misfire.
---Garret
S&B Intake
Studded and deleted
CTS w/EGT
post #6 of 11 Old 02-05-2014, 11:50 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I had a similar issue. On these cold Florida mornings the truck would miss and smoke until warm-eot 115.
Well I had a battery crap out on me and it threw a FICM code and three injector codes even tho my voltages were very good.
I tossed another ficm in it and noticed my injector buzz was louder and ran longer. Started it up and it ran as smooth cold as it does hot.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #7 of 11 Old 02-06-2014, 12:14 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
What does your FICM volts look like while it's running rough? Did you notice any wire chaffing while you had the truck apart? These 6.0 are known to have several chaffing problem areas. Next time it starts to run rough, jump under the hood and try moving/wiggling all the wiring harness's to the FICM... and out of the FICM to the valve covers. You also never said how long it takes for the smoke to clear up.
Juinor, it should be noted that different strategy codes will cause different injector coil buzz sounds. Not sure what strategy does what but I do know it changes the way they sound when cold. Might be worth looking into. Dave has quiet a bit of knowledge on this.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #8 of 11 Old 02-06-2014, 07:41 AM Thread Starter
Quoted: 2 Post(s)
From what I can tell the smoke doesn't clear up until the truck is nearly at full operating temp, 180*-192*.
Honestly I didn't look at the ficm volts while it was running rough, I'll make a point to snapshot the CTS next time it does that. While I had the truck apart I checked the harness for issues and didn't see any issues, but I will try wiggling the connectors next time.
Fwiw, the FICM volts don't drop below 47.5 during warmup.
---Garret
S&B Intake
Studded and deleted
CTS w/EGT
post #9 of 11 Old 02-06-2014, 08:59 PM
keep good batteries in the ol 7.3 and have no problems. set the 6.0 on fire and collect insurance money
sean andreano is offline
post #10 of 11 Old 02-06-2014, 08:59 PM
good luck in whatever direction you go
