F250 6.0 cylinder 7 injector circuit low - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-04-2014, 01:27 AM Thread Starter
I have a 2006 f250 I have had huge problem with abot
It a month ago my truck started missing and threw a p0279 code which is cylinder 7 low circuit so right away I replaced the injector with a ford remanufactured injector and it still missed and brought the same Code so then I looked at the ficm which had 47v key on engine off and 36v engine on so I sent it off and had it rebuilt and got it back and installed it and that didn't work and it now reads 48v key on and 48v engine on so then I looked at the injector harness which looked fine but I replaced it with a brand new ford harness thinking for sure that was the problem and I still have the same problem I replaced the batteries and that didn't help and I even did the trick were you touch the starter solenoid to the positive terminal and it cranks nice and even so I'm out of ideas and every forum I've read just states what I've done so far should fix the problem.
Trickalloy is offline
post #2 of 3 Old 03-14-2015, 08:59 AM
MurderedStroker's Avatar
Quoted: 18 Post(s)
I am having a similar issue right now myself. cylinder 1 tho. so far i have replaced the FICM with a known good one with no results. battery health looks good to me so i am now concerned with the harness. did you find the issue that was causing your problems?
2006 F-250 CCSB XLT
Studed, 175/stock, EGR gone, blue spring kit, edge insight, 03 turbo, MBRP 4in turbo back, 8in MBRP black tip, SCT X3, Kicker door speakers, Boss Audio Touch Screen, 5% tint all the way around, in need of some new shoes!
2004 f350 ECLB *sold*
MurderedStroker is offline
post #3 of 3 Old 03-18-2015, 12:22 AM
Gadgetguru's Avatar
Quoted: 436 Post(s)
Garage
From experience, ensure the the connectors are fully seated in the FICM. You can place a piece of heater hose under the connectors when you tighten down the FICM to put pressure on them. Or put zip ties around the connectors and FICM and tighten. Check all the other connectors. I assume the new injector had new o-rings and washer on it. Ensure the injector was torqued properly, cleaning out the bolt hole before installing. Another thought, maybe a long shot, checking ground wires. Oh, and please use some sentence structure and punctuation to make it easier to read and understand what you are posting. Thanks.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is online now
