Oil in my intake and intercooler piping? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-02-2014, 03:32 PM Thread Starter
Ive recently been adding some gauges to my 03 six liter, When I removed my intake elbow to drill and tap for the boost hook up I noticed an excess of oil sitting in the boot and covered down in the manifold its self. Just trying to find out if this is common or do I have something wrong or going wrong with my baby. Thanks to anyone who has some knowledge on this topic! Hugh.
2003 Single Cab Long Bed Sonic Blue With 47,000 when I bought it 55,000 as of 1/17/14
Mods: ARP studs, factory head gaskets, Egr delete, afe stage 2 intake, 4" Turbo Back, Zoodad, Sinister coolant Filter, Goodyear Dura-tracs. Sct Live-wire 5015 with Innovative tunes!
YamahaAwesome is offline
post #2 of 11 Old 02-02-2014, 04:02 PM
Quoted: 2 Post(s)
Common, from my understanding it's part of the crankcase ventilation system, and that oil is necessary for proper turbo lubrication. Not really sure if it's necessary, as quite a few people reroute the ccv so that it doesn't dump oil into the intake.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #3 of 11 Old 02-02-2014, 04:38 PM
crank case is more than likely overfilled.
egr trucks seem to like to be left a quart low.
POWER-STRUCK is offline
post #4 of 11 Old 02-02-2014, 04:45 PM Thread Starter
Okay few! When you say egr trucks. Do you trucks that have it deleted or ones that still have them in? Thanks!
post #5 of 11 Old 02-02-2014, 04:48 PM
anything that came equipped with egr. even gas engines. just fill to the middle of the cross hatches and your engine will thank you.
post #6 of 11 Old 02-02-2014, 05:04 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
I'll put my flame suit on and say 2 words...
Draft tube
Let the games begin.
Please
You could save the life of a sick child
NYC F-350 is offline
post #7 of 11 Old 02-02-2014, 05:10 PM
a road draft/CCV reroute is not needed if the proper oil levels are used
post #8 of 11 Old 02-02-2014, 05:10 PM Thread Starter
Draft tube
Uh oh, Thats doesn't sounds very good. What do you mean when you say draft tube? Something I can fix to hopefully avoid needing the flame suit?
post #9 of 11 Old 02-02-2014, 05:37 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
What is happening is that the oil that you see actually takes a long time to build up. It escaped the engine in the form of a vapor, but as the vapor cools, the oil drops out and collects on the interior of the piping.
Diesel trucks have been running draft tubes for forever and a day.
Soon enough, there will be some people dropping in here saying that by putting a draft tube on my truck I am harming my engine and warning not to do it for <blah> reason....
My take on it is this:
Don't try to get all fancy and run the line all over hells creation because you don't like the smell.. run it straight down. My draft tube is less than 36 inches long. Don't like the stink coming out of the CCV? Leave it stock.
Running it other than straight down can result in some serious problems like turning your engine into the most expensive oil fountain you have ever seen, and if that happens it will kick you really hard right in the wallet.
That should stir the pot nicely......
Ready
Set
Go
Please
post #10 of 11 Old 02-03-2014, 08:46 PM
I did my own PVC relocate for around 60.00 bucks and my time. Itís on the driver side just under the front of the bed, looks the same as the expensive kits. The oil you see is from the PVC and itís going into your air intake just before the turbo, it is not a good thing It is not meant to supply oil to the turbo lol where do these guys come up with this stuff. Itís an emissions thing PVCís have been around a long time, but itís not a good thing with a high boost diesel like the 6.0. That oil will leak from your turbo boots and get in your air to air cooler. I know I spent many hours cleaning my after cooler after 8 years of not realizing how much oil vapors are sucked out though the PVC. This is a turbo charged engine so with the PVC going in pre-turbo guess what happens when you have high boost, sucks out the vapors at an excessive rate compared to a naturally aspirated engine. You wonít notice a difference in oil levels on the dip stick as this is vapors and over time it will put a lot of excess oil in a system that should not have oil in it. When I did the relocate I also pulled the air to air and degreased it on the inside and it was nasty it was never meant to have oil in an air to air cooler, and the turbo boots and tubes if you take them off without really cleaning them before reinstalling them you will blow a boot off with high boost and itís no fun pulling over just to put a boot back on. My cooler is much more efficient now and I have zero oil in my air to air system. Good luck just my two cents
PowerMax Turbo-MFS Billet Wheel SCT Livewire TS- Vivianís Tunes S&B Intake MBRP 4 ďS.S Straight piped APR Studs Warren 155/30 Injectors New Oil Cooler EGR Delete Blue Spring Mod 6.4 Banjo Bolts Delete PVC Relocate Coolant flushes with Restore and Restore Plus Cat ELC Coolant Coolant Filter High Idle Mod Clutch Fan Mod Zooda Plus Mod
BP-1 is offline
