Damaged Turbo Bolt - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-01-2014, 07:24 PM Thread Starter
Gus_hauler's Avatar
Damaged Turbo Bolt
Help! I have spent all day trying to remove a rounded off turbo mounting bolt. (of course, the back one) I've had zero luck. I've tried two types of "bolt extractors" from Sears, and neither work. I think if I could get back there to tap on the top of the extractor so it would bite into the bolt head it would probably work, but I sure can't get a hammer back there.
Anyone have any tips, or suggestions I could try?
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #2 of 7 Old 02-01-2014, 07:36 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
JB weld a socket on there
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 7 Old 02-02-2014, 01:35 AM
Please don't kill the messenger here. You have benn trying to get your extractors to fit on the rounded mounting ear not the head of the bolt.
In 03 and early 04 the rear mounting bolt comes into the pedastal vertically not horizontaly.
The first one I pulled I did the same thing fought it for a full shift, indesperation I finally pulled it pedestal and all. When I got it to the bench you could clearly see all the scratches on that ear where I had been try to get wrenches,sockets and extracters on it. Bolt head pointing straight up in the air just laughin at me.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 7 Old 02-02-2014, 05:03 AM Thread Starter
Gus_hauler's Avatar
Thanks Dannyboy, I'm going to try and get my phone back there today and take a picture of what I'm dealing with. My next question was going to be if it was possible to pull the turbo out with the pedistal still attached. Thanks for letting me know it is possible.
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
post #5 of 7 Old 02-02-2014, 05:48 AM
IIRC 2 of the bolts will be a bugger, you can only get on them from one angle and will be able to turn only 1 flat at a time.
post #6 of 7 Old 02-02-2014, 07:33 AM
I have found that a good inspection mirror and light is a necessity any time you are working around the turbo. Such as Lowe's Home Improvement
ky450 is offline
post #7 of 7 Old 02-02-2014, 10:23 AM Thread Starter
Gus_hauler's Avatar
I'm happy to report that I finally got the last bolt out after a LOT of cursing. I ended up getting one of the bolt extractors to work. Unfortunately once I opened up the turbo, I found a TON of damage. I'm going to start a new thread to ask people's advice on what to do next. Thanks all
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
