"New" injectors, P0282 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-31-2014, 07:29 AM Thread Starter
Gadgetguru's Avatar
Quoted: 444 Post(s)
Garage
I'm moving this from my build thread to here. Coming home from work one night, my truck began to run rough, spit, sputter, and buck. Have a P0284 code. I've checked readings using Torque Pro app, cleaned the EGR valve, cleaned the #8 injector, and re-installed with new o-rings and washer. (I had a thread on FTE about it.) I also needed a new thermostat which I replaced. Truck still ran terrible. At this point Iím assuming I have a bad injector(s) so I ordered a set of 8.
That was two months ago. Finally got a set of 175/stock injectors and installed. Same issues, truck still runs like crap. Now I have a P0282 code and no other codes.
Also just installed, blue spring, two new batteries, 135amp Alternator with overdrive pulley, standpipes, dummy plugs, BD intake elbow, metal CAC pipe, all new CAC boots, SCT w/ street tune from Tony Wildman, GlowShift gauges, and coolant degas bottle cap.
I have a ScanGauge II and Torque Pro app. Fuel pressure gauge stays maxed at 100psi. GlowShift website says this is a bad ground. Moved ground wires around, still stays maxed.
KOEO:
ICP = 43
IPR = 14.8
EBP = 14.4
Idle:
ICP = 580
IPR = 22
FICM= 48.5 - 49
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #2 of 5 Old 01-31-2014, 08:09 AM Thread Starter
Gadgetguru's Avatar
Quoted: 444 Post(s)
Garage
Wiggled the injector wiring harness beside the FICM while she was running. Whoa! Did that make her go crazy. Guess I'll be unwrapping all that wiring!
- Michael
- Click
for details
for details
for details
post #3 of 5 Old 01-31-2014, 08:18 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Don't waste your time with unwrapping the injector harness and trying to repair it. It has all kinds of shielding weaved in and out of it. I think you can buy a new harness for around $200 from Sunrise Ford on here. If it's the main harness, then that's a different story.
dhanna6powerstroke is offline
post #4 of 5 Old 01-31-2014, 02:38 PM Thread Starter
Gadgetguru's Avatar
Quoted: 444 Post(s)
Garage
It appears it was a loose FICM connector. I use a long screwdriver to pry up under the connectors to make sure they are fully seated. But apparently they weren't. This time I applied dielectric grease to the plastic around the plug and then used the screwdriver pry method. Truck fired right up and ran smooth!
- Michael
- Click
for details
for details
for details
post #5 of 5 Old 01-31-2014, 02:39 PM
04cr450's Avatar
I agree^ I replaced my harness when I did my injectors. Think is was $210 shipped to the house. Also safe insurance as well knowing that the wiring is fresh
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
