Won't start after egr delete and oil cooler install - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-30-2014, 06:05 PM Thread Starter
I installed a ipr gen 2 egr delete and a new factory oil cooler and my truck won't start. It cranks normal and there is a small amount of black smoke that comes out of the exhaust like it's burning fuel but the motor doesn't even try to fire. Any ideas ?
jtice87 is offline
post #2 of 5 Old 01-30-2014, 06:20 PM
Might have pulled in carbon from the intake, take a can of silicon and spary into the intake while cranking, might getcha somewhere
rob2111 is offline
post #3 of 5 Old 01-30-2014, 06:24 PM
andyjman's Avatar
Quoted: 2 Post(s)
Check to make sure all ur connectors are plugged in. Does it give u any codes?
05 F350 CC LB FX4 Lariat, ARP studs, Barder 2.5 turbo,warren 175/30 injectors, Odawg ported manifold, S&B cold air, sinister coolant filter, Twisted Stage III Trans, DPC Conv, Mishi Rad BPD water pump, EGR delete, MBRP turbo back exhaust no muffler or kitty, edge insight monitor, tunes from Matt @ geadheads, rancho rs9000xl adjustable shocks .
My House Has A Ford Problem!!!! lol
andyjman is offline
post #4 of 5 Old 01-30-2014, 06:26 PM
Well the EGR delete will have nothing to do with the oil issue except for the fact that you opend the oil system. You could simply have air in the system to a botched repair.
You need to see what your high pressure oil pressure actually is. It takes a min of 500 psi to start. Possible ficm issues, wireing etc. You need to have it scanned and a few tests run.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 5 Old 01-30-2014, 06:39 PM
andyjman's Avatar
Quoted: 2 Post(s)
True, it could still be trying to fill the oil rails.
andyjman is offline
