Water in Fuel Light - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 29 Old 01-30-2014, 04:09 PM Thread Starter
tinygiant's Avatar
Water in Fuel Light
All,
On the 350, I had the water in fuel idiot light appear on the dashboard. I emptied out the reservoir and off the light went. I've owned 6.0s for several years and this is the first one I've seen. Same truck ... light was back on and the reservoir full again in two months. Any idea why it wouldn't be on for years and now it's on again within months?
..ed..
___|0o0|___
'04 Excursion PSD (Hers)
'03 F-350 PSD (His)
'05 BMW 325i (Her Daily Driver)
'08 Harley Davidson Fat Bob (His Daily Driver)
'79 Fairchild Republic A-10C
tinygiant is offline
post #2 of 29 Old 01-30-2014, 04:10 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
You are buying crappy fuel?
Seriously, was there water present when you drained it?
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 29 Old 01-30-2014, 04:16 PM
midnite rider's Avatar
Quoted: 285 Post(s)
drain fuel pump in a couple days in a glass jar you will find water
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 29 Old 01-30-2014, 04:18 PM Thread Starter
tinygiant's Avatar
Same fuel I've been buying for the last two years. It was a mixture of water and fuel in the reservoir. I'm not too worried that the light illuminated, more with how quickly it illuminated after I last emptied it. Any way I could've gotten a bad fuel filter (anyone ever heard of that causing this problem)?
..ed..
___|0o0|___
'03 F-350 PSD (His)
post #5 of 29 Old 01-30-2014, 04:27 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
Even if you have kept up with your filter changes, and do not see water when you drained the HFCM, you can still get that light.
Best to start this whole journey with new filters if it has been awhile.
Get a can or two of carb cleaner, bend the straw at about a 45 angle, remove the drain plug and spray inside in all directions. That would clean the crap out that tends to build up in that housing. Depending on how bad the corrosion is that may or may not work.
Please
post #6 of 29 Old 01-30-2014, 04:40 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
The tv show truck u also did a nice little show on trouble shooting this. I believe you could find that on speedtv.com?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
Heavy_GD (02-03-2014)
post #7 of 29 Old 01-30-2014, 06:19 PM Thread Starter
tinygiant's Avatar
Thanks for the pointers. I'll start checking out the system tomorrow morning.
..ed..
___|0o0|___
'03 F-350 PSD (His)
post #8 of 29 Old 02-03-2014, 08:15 AM
Heavy_GD's Avatar
Quoted: 1314 Post(s)
Feedback Score: 3 reviews
Bumping this up, one because the vid is pretty good.
Two because I wanted to ask if you guys are using this (below) or if there is an upgraded solution.
HFCM Water Separator Drain Plug Upgrade 6E7Z-9C082-A
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #9 of 29 Old 02-03-2014, 09:43 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
I am using that. It is a hell of alot easier to deal with/remove than the original.
Please
post #10 of 29 Old 02-03-2014, 09:45 AM
Heavy_GD's Avatar
cool, thanks.
GD
Heavy_GD is offline
