Little Vibration - Ford Powerstroke Diesel Forum
Old 10-16-2008, 01:46 PM
Little Vibration
I have found there is a small vibration like there is mount for something loose. I can make it happen and hold it there when I am gaining speed from a stop to 30 mph and holding the rpm at alittle above 1200. If I just barely push the accelerator to hold the speed at 30 it sounds like exhaust but I have checked all the couplers. The sound is coming from under the hood/ driver side. If I push the accelerator harder to bring RPM's and speed up it goes away. any thoughts?
Old 10-28-2008, 04:47 PM
Had the same problem. I took mine back to the dealer and they put whats called a damper on it. Now every time i put it to the floor there is no vibrations.
(not a huge problem, just a small fix)
Old 11-11-2008, 11:05 AM
Sorry for not replying back. I figured everybody thought I was: tard: because of not even getting a bump. But would that be like a harmonic balancer. Or some other kind of damper?
