Engine doesn't match? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-30-2014, 01:02 PM Thread Starter
king_of_ctown's Avatar
Quoted: 2 Post(s)
So, I have been going through my truck doing some check work (oil, tranny, coolant) and decided to get my serial #'s together for reference. Lo and behold, the serial plate on my engine is stating that it is a 05' build. Seeing as how my truck is an 04', is there anything I should worry about here? As far as FICM, ECM, etc... not being set properly or does it matter? I bought this truck roughly a year ago and can't believe I didn't check this stuff. Furthermore, I had some pretty extensive work done on it by Ford and they never mentioned this. Again, does it matter or should I just forget about it? Thanks for the help.
king_of_ctown is offline
post #2 of 7 Old 01-30-2014, 04:37 PM
If the engine replacement was done by Ford they by policy would have done any flashes or programming changes if any. Your probably good to go.
Ya can always have a dealer run the vin and engine numbers and find out.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 7 Old 01-30-2014, 04:43 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the quick reply. I'm not sure as I bought the truck from a used diesel dealer. But I will definitely get with Ford to see if they can verify the match for me. I guess what I am wondering is whether something like this should have been listed on my Carfax or in my paperwork from the dealer I purchased from?
post #4 of 7 Old 01-30-2014, 04:45 PM
Quoted: 348 Post(s)
Feedback Score: 5 reviews
Whatever the reason or "issue" was or is...
There is nothing to be concerned about. If the truck runs, then the FICM and engine are interchangeable. It would not run if it wasn't the same. Most computers just have different flashes for different effects. nothing dangerous.
Just enjoy your truck!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #5 of 7 Old 01-30-2014, 04:46 PM
By law in most states it is supposed to be listed but it don't always happen.
post #6 of 7 Old 01-30-2014, 05:04 PM
Heavy_GD's Avatar
Quoted: 1338 Post(s)
Feedback Score: 3 reviews
Who can get OP an Oasis?
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #7 of 7 Old 01-30-2014, 06:08 PM
The thing to remember Oasis and Carfax can only report on what has been actually reported to them.
Fords Oasis will show warrenty work but not always a job you have done on your own initive such as changeing glow plugs or injectors.
Car fax works primarily off of insurance claims. no claim filed no report.
My wife bought a 05 dodge neon in 07, she ran a car fax nothing showed up.
After doing some front end work on it a few years later, I could see where the entire front clip radiator support and both fenders had been repaired.
Turns out the used car dealer had repaired it out of pocket, no insurance claims ever filed.
