overlap on shop labor charges?? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-29-2014, 04:55 PM Thread Starter
Hey there, I got some quotes for having some work done on my f550
egr cooler 2400 for bulletproof
valve cover gasket leak
do those 2 items overlap, i got quote 290 for the valve cover gasket that is leaking
also thinking about having them replace the oil cooler with a new oem...is this also overlap, I am hoping that its all in the same area so it should be essentially just the cost of the part itself.
At this same time they said they don't flush the system, I naturally think this should be a given...is this common?
Thanks
2015 F350 Platinum CCSB SRW
100% stock
SOLD: Black 08 F350 FX4
Spartan tuned
MBPR DP Back straight pipe
20' XD Hoss's
325/60 Duratracs
Leveled
chinaman is online now
post #2 of 3 Old 01-29-2014, 05:31 PM
Heathrm's Avatar
There would minimal overlap in the labor for the egr cooler and the valve cover gaskets. If you are going to do the oil cooler at the same time, then there will be a major overlap and they shouldn't charge you the flat rate for the oil cooler and the flat shop rate for the egr cooler.
2004 Excursion Limited, 211,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #3 of 3 Old 01-29-2014, 06:36 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1685 Post(s)
What he said^^^
When I do these I usually add 1hr labor for oil cooler rebuild while doing the egr. Also depending on year you may have them see if the STC fitting has been updated or not.
toren302 is offline
