Why is my 6.0 "spotting" with coolant? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-29-2014, 05:26 AM Thread Starter
ChrisAU's Avatar
So I have to go through an inspection every morning (work at a nuclear plant) so I have to pop my hood every day. More often than not I get a faint smell of antifreeze. I can see some spots, not puking, but just a few red spots on the coolant tank. Its been like this for probably 6 months now. I'll wipe it off and no matter how I drive the truck, whether like a grandpa or like a bat out of hell within a week there will be a few more spots. I've added coolant once - maybe 1/5 gallon a couple months ago. I think that is gone again now.
I drove 45 miles on Monday night in a terrible hurry, drove it like it was a race car and never saw any abnormal temps and it never puked and I couldn't smell antifreeze.
Deltas are usually 1-4 degrees, never in any conditions do I see over 7*. No oil in the coolant that I can tell.
Just replaced the tank cap and still have the same problem.
What could be going on here?
'06 F-250 6.0 CCSB FX4 Lariat
Edge Insight CTS w/EGT | SCT SF3 | SRL+/Looney/Wildman | ARP Studs | IPR Gen 2 EGR Delete | PHP Atlas 40 | '03 Turbo | 155/Stock Warren Sticks | Banks Intake, Exhaust & Intercooler | Pioneer AVIC-X940BT H/U w/ BU Cam | Kicker 10" Subs | Blue Spring | Sinister Coolant Filter | T6 | Cat Delete | 35x12.50x20 Toyo AT II's | Paint Matched Grill | Tint | 2.5"/2" Lift | Bilstein 5100s | RanchHand Black Grill Guard | Custom Emblems | '08 Diff Cover | FP & Boost Gauges
ChrisAU is offline
post #2 of 6 Old 01-29-2014, 05:55 AM
Defective cap, overfilling [the new full is actually below the minimum line on the bottle] nearly invisible hairline crack etc.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 01-29-2014, 06:05 AM
ZMANN's Avatar
Quoted: 1784 Post(s)
ford likes to replace the degas bottle when this happens
they say the sealing surface can distort
if it were mine I would tee into the top hose at the degas bottle and pressure test
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 01-29-2014, 06:11 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Beginning stages of head gasket failure.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 6 Old 01-29-2014, 06:22 AM
While that is always a possibility his temps at this point show no signs of impending gasket failure, as Zman says only a pressure test can really tell.
post #6 of 6 Old 01-29-2014, 06:26 AM
dfuzz78's Avatar
Temps don't have anything to do with gasket failure.
He's deleted already.
His head bolts have started to stretch.
Start saving for a head gasket job, because it's not going to get any better.
Denis "Lt. Sled"
Last edited by dfuzz78; 01-29-2014 at 06:30 AM. Reason: Removing part about him having a BPD oil cooler
dfuzz78 is offline
