Ficm - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 21 Old 01-28-2014, 03:41 AM Thread Starter
firststroke's Avatar
Ficm
So I got my livewire ts last night and hooked it up. Start the truck this morning and it reads fixn at 24v the only time it shows above 46v is when idling. When on the throttle or moving it's all over the place. What do you guys think? I have not tuned the truck it's still stock just monitoring right now. Here's a pic of 45 mph cruising.
S&B CAI
Diamond eye 4" Turbo back
6.4L banjo bolts
Blue Spring upgrade
Livewire ts 5015
2014 bed
firststroke is offline
post #2 of 21 Old 01-28-2014, 03:43 AM Thread Starter
Here's one just idling parked at work.
S&B CAI
6.4L banjo bolts
Blue Spring upgrade
Livewire ts 5015
2014 bed
post #3 of 21 Old 01-28-2014, 05:15 AM
Call Ed at ficmrepair.com...
Betcha your due for a repaired or new FICM... It must stay above 46v at all times.
You MIGHT try to check the plugs to ensure that they are plugged in snug...
Any issues with the truck running? Starting?
TxOutlaw is offline
post #4 of 21 Old 01-28-2014, 05:19 AM Thread Starter
Only issues are when it's cold. Once it warms up its great. I'm gonna check connections this afternoon. If I have it plugged in it'll start when it's freezing out no problem. If it's not plugged in there's no way in hell it's gonna start.
S&B CAI
6.4L banjo bolts
Blue Spring upgrade
Livewire ts 5015
2014 bed
post #5 of 21 Old 01-28-2014, 05:21 AM
I am with ya there... Year round for me... I will be trading in a faulting 58v ficm to Ed and getting atlas 40 tuning while I am at it!! His website is amazing and you will learn a ton about FICMs...
TxOutlaw is offline
post #6 of 21 Old 01-28-2014, 07:17 AM
SargentoPistola's Avatar
Well your battery voltage is good, your alternator seems to be doing its job, which leaves a bad FICM to blame.
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
post #7 of 21 Old 01-28-2014, 09:27 AM Thread Starter
I hope not. The guy I got it off of was running bad batteries though. I think they burnt the alternator up so the could've messed the ficm up too. I'm gonna check the connections though and go from there. Will the ficm voltages being low cause hard cold starts?
S&B CAI
6.4L banjo bolts
Blue Spring upgrade
Livewire ts 5015
2014 bed
post #8 of 21 Old 01-28-2014, 09:42 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Yes
Please
You could save the life of a sick child
NYC F-350 is offline
post #9 of 21 Old 01-29-2014, 02:58 PM Thread Starter
Ok I did the ficm repair today and the truck started without being plugged in when it was 30 degrees out. That would not have happened before.
huck2080 likes this.
S&B CAI
6.4L banjo bolts
Blue Spring upgrade
Livewire ts 5015
2014 bed
post #10 of 21 Old 01-29-2014, 03:11 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
Then you're officially good to go. 24v on throttle is beyond a bad ficm
@loxdce
LoxDiesel is offline
