whistling from intake and slight power loss - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-28-2014, 12:46 AM Thread Starter
Whistling from intake tube, goes away under acceleration or if you push down on the rubber area of air box tubing. Also when it started I believe my boost has went down from 25 to 20. Any ideas what it might be?
billybad05 is offline
post #2 of 5 Old 01-28-2014, 05:19 AM
If it is affecting your boost, check the passanger side (hot) CAC Tube and boots for leaks. I would check both for leaks while you are there. Simple Green cleaner spray around and it will bubble just like checking a tire for a leak... I was able to get a cold side leak to bubble at idle, not sure about the hot side...
TxOutlaw is offline
post #3 of 5 Old 01-28-2014, 07:37 AM
As mentioned check the air induction pipeing and even the rubber parts of the air box sometimes splits..
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 5 Old 02-02-2014, 01:36 PM Thread Starter
thanks for the replys it stopped doing it, dont know why
post #5 of 5 Old 02-02-2014, 08:16 PM
04cr450's Avatar
could be your filter indicator on the side of the filter box making a hissing noise... mine hisses pretty bad but no harm in it leaking
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
