Odd whinning sound around 1200rpm. Video - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-26-2014, 02:11 PM Thread Starter
I could use some help here fellas. 6.0 auto 2006 with an odd whine that seems to be coming from the turbo. I dont have to be driving down the road or in a gear. Doesnt need to be loaded, doesnt need to be hot or cold outside, truck doesnt need to reach operating temperature, its just a low groan/hum that starts around 1250rpm and gone by 1500 or so, the groan is replaced immediately with the "healthy turbo" whistle sound. I let off the accelerator and it groans right thru the rpm band on the way down. I took a quick video and hit the idle switch 3 times. You can hear it clearest on the 2nd and 3rd attempt. Truck runs like a top, good power and good boost, clean and healthy fluids all around. Pulled the intake expecting defective turbo fins or shaft play, but I found none of the above. Any ideas are much appreciated.
6.0 f250 noise - YouTube
rwdunson is offline
post #2 of 7 Old 04-23-2014, 05:41 AM
Soledad's Avatar
Garage
I was wondering if you ever figured out why that sound was occurring? I have the same exact sound and notice that it comes on at the same RPM that you were seeing and lasts almost until 2000 RPM. Anything after 2000 and either I just can't hear it or it goes away.
I pulled the intake yesterday so I could get to the turbo wheel and found it has about 1/16" of vertical and horizontal play but no in and out play so I don't think it's the turbo. And I'm sure it's not the power steering pump. I'm not exactly sure what could make that type of sound.
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #3 of 7 Old 04-23-2014, 10:06 AM
Blown F-150's Avatar
That is exactly what mine sounded like when the up-pipe had a cracked bellows. Crawl under the truck with a light and check around the up-pipe bellows and firewall. If there is any black soot, you've found your culprit.
2006 F-350
Lariat, Crew Cab 4X4
EGR Delete, K&N Intake, MBRP Exhaust, Level kit, Custom Ford Badges, Tranny/EGT/Boost/Fuel Pressure Gauges.
Gryphon FICM tuner
SCT XCal 3 with custom tunes
ScanGauge II
Updated STC fitting
High idle mod, blue spring update.
Blown F-150 is offline
post #4 of 7 Old 04-23-2014, 10:40 AM Thread Starter
I was told bad bearings in the turbo. A bad thrust bearing to be exact.
rwdunson is offline
post #5 of 7 Old 04-23-2014, 10:51 AM
You should be able to confirm by pulling the intake and spinning the impeller by hand, if it's smooth, I doubt you have turbo bearing issues.
Although, if you trust the source of the diagnostic, it's not a tough fix, just a few bucks or opportunity for an upgrade...
2006 F-350
Gryphon FICM tuner
ScanGauge II
Updated STC fitting
post #6 of 7 Old 04-23-2014, 11:39 AM
Soledad's Avatar
Garage
Any one know how "easily" the turbo wheel should spin? When I spin mine I maybe get two-three full rotations before it stops. And oddly it spins a bit easier one way than the other.
I've looked for soot a few times on all of the up-pipe connections but I'm just not seeing anything. Soooooo......I'm going to wrap tinfoil around them, drive it for a while and see what I get.
Soledad is offline
post #7 of 7 Old 04-23-2014, 12:08 PM
I think you have a turbo issue. Mine spins very freely, if I give it a flick with my finger, it will spin for a few seconds.
2006 F-350
Gryphon FICM tuner
ScanGauge II
Updated STC fitting
