Distilled water questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-26-2014, 07:01 AM Thread Starter
Hello,
I started flushing my truck with distilled water yesterday in preparation to switch over to Rotella Ultra ELC. After doing some more reading I need to replace my thermostat since my truck doesn't seem to fully get up to temp. It normally runs around 175-180 according to my SCT. Deltas before the drain were around 9 degrees, and are about the same 2 distilled water flushes in. Problem is it's Sunday and I can't get a thermostat from Ford till tomorrow, if they have one on hand.
How long can I leave the water in my truck? I live in Chula Vista and the temps are supposed to be in the 65-75 range next week. I know 100% distilled water will leech minerals from metals in the cooling system but that takes more than a few days right?
w00ht is offline
post #2 of 7 Old 01-26-2014, 07:21 AM
information regurgitator
NYC F-350's Avatar
Quoted: 52 Post(s)
Nope, just a few hours. Might be better off getting the ELC in there, and losing a couple cups worth to replace the thermostat.
It doesn't take long to pull the lower rad hose off into a 5 gallon bucket anyway. Then just pour it back in.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 7 Old 01-26-2014, 08:05 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
^^^ Don't leave just H2O in it. Put in the ELC and just drain out about 2 gallons when you replace the T-stat. If you are clean on the draining, just pour it back in. If you are fully anal about it, filter the coolant when you put it back in.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 7 Old 01-26-2014, 09:20 PM Thread Starter
Thanks for the replies, I ended up flushing it a few more times this afternoon and then filling it with ELC. That way I don't have to be in a rush if I feel like being lazy this week (happens a lot ) I have 2.5 gallons of concentrate left so I'll mix some 50/50 up to top off after I swap the thermostat if I don't catch all of it.
w00ht is offline
post #5 of 7 Old 01-27-2014, 02:05 PM
OT. Nice bateau there two icebergs.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 7 Old 01-27-2014, 03:54 PM
Quoted: 47 Post(s)
8.1l Volvo (496 GM big block) 23' Epic. If I get 2 mpg we are doing good! In a full day we go through 30-40 gallons. Right now it is doing its best imitation of an ice cube in the storage shed. Maybe later this week I will post a picture of a snow bank!
Frank
Working for Toys
post #7 of 7 Old 01-27-2014, 06:55 PM
yamasaki's Avatar
2mpg!? In my dreams!
I got two old v6 two strokes hanging off my transom
2007 6.0 CC FX4 Lariat
Insight CTS, SCT 3015, EGR Delete, 4" TB Exhaust w/hollowed cat, ARP studs, OEM HG, Coolant Filter, BPD Water Pump, K&N CAI, King Ranch interior, Pioneer AVIC x910bt, Nitto Terra Grapplers
yamasaki is offline
