fuel gelling, additivies, and outside tempeartures - Ford Powerstroke Diesel Forum
post #1 of 10 Old 01-25-2014, 02:09 PM Thread Starter
I am a new owner of a diesel truck. I purchased a Ford F-350 6L in August with 88,500 miles and now have 101,500 miles. I park my truck outside and use a block heater that is plugged in whenever I am not driving (when temperatures are 32 F or below). I live in the Chicago area and the temperatures have been unusually low.
In the last three weeks I have had problems with fuel gelling or ice crystals three times. The first two times the temperatures were -15F and -10F and I had driven about 20 minutes on the highway before having problems. The third time the temperature was about 5 or 10F and I drove four hours before having problems.
I was using Howe's fuel additive when I had the first two problems, then switched to Seafoam before the last problem. I have since switched to Power Service 911.
I am unclear on how low an outside temperature is realistic to drive my truck and I have seen on the forum, there are a lot of different opinions on fuel additives. I am thinking about adding a fuel line / filter heater because the temperatures appear to be slipping into the single digits and below zero for the foreseeable future.
I am interested in any feedback on outside temperatures, additives, and fuel line heaters.
PrairieDrilling is offline
post #2 of 10 Old 01-25-2014, 02:22 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site. There is a number of guys on here from Alaska and a big ole boat load of Canadian's that laugh at our "cold weather" issue's. So I don't believe the 6.0 is a fair weather only truck.
When was the last time you drained your water sep? As far as fuel additives I run the white bottle of power service and 2 cycle oil. 16 ounces per fill up.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 10 Old 01-25-2014, 02:39 PM
midnite rider's Avatar
Quoted: 285 Post(s)
I run diesel clean white bottle and optilube have never had problems, but this low sulfur fuel sucks big
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 10 Old 01-25-2014, 02:42 PM Thread Starter
I have changed the fuel filters twice. Once after about 10,000 miles and I changed them after the problem with gelling / ice crystals. I am embarrassed to say I did not think to drain the fuel water separator. I'm not even sure where it is so I guess I have a small project for tomorrow morning.
post #5 of 10 Old 01-25-2014, 02:44 PM
linehaul's Avatar
Quoted: 7 Post(s)
Garage
power service / diesel kleen--- white for winter, silver for summer. at below 0 not plugged in for 12hrs overnite my 6.0 starts right up, not happy but starts.
linehaul is offline
post #6 of 10 Old 01-25-2014, 03:16 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hey thanks for the reminder!. Its been about 3 months since I drained mine. Just ran out and did it. Not to bad....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 10 Old 01-25-2014, 03:25 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
[QUOTE=PrairieDrilling;7998770] I'm not even sure where it is so I guess I have a small project for tomorrow morning.[/QUOTE
The filter,just about directly below the drivers seat,hooked onto the inside of the frame, toward the front you can see a little plug with a allen head plug. I use a old mason jelly jar to drain into.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 10 Old 01-25-2014, 05:46 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Don't waste your money! An in-line heater while driving would be overwhelmed by cold fuel. There is a reason why Ford moved away from the heater they had in the 03s, it didn't work. Your best course of action is to ensure the station you fill at stocks proper fuel for the expected temperatures. Try to stay away from #2 fuel that many big trucks run, since many that run #2 in cold climates have immersion heaters in the main tanks or use it before it gets too cold in the tank.
Been 6 months for me. It would already be frozen if I had much water in the trap! Too darn cold right now.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #9 of 10 Old 01-25-2014, 06:00 PM
Regulated return fuel system. With eliminate most problems and also helps protect injectors and will simply make the truck run better
Power-Struck dot com
POWER-STRUCK is offline
post #10 of 10 Old 01-27-2014, 05:30 PM Thread Starter
Thanks for all the advice. I found the drain so I've added that to my routine maintenance. I'm also working on changing additives.
Tags
fuel additive , gelled fuel. diesel 911 , temperature
