Overmilled heads now what? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-22-2014, 03:59 PM Thread Starter
Krug's Avatar
Quoted: 14 Post(s)
Short story is I had the heads of to do a stud and gasket job, had the heads milled for flatness, kept bending the #5 pushrod so I took it to Ford and they tore every thing down and determined that the heads were overmilled and the valves were hitting.
What I am now wondering is if I buy a set of reman heads would this be worth while, or is there a high probability that there is lifter and cam damage? Meaning I need a crate motor?
Krug is offline
post #2 of 7 Old 01-22-2014, 04:31 PM
Quoted: 48 Post(s)
did they not sink the valves when they cut the head?
drunk on diesel is offline
post #3 of 7 Old 01-22-2014, 04:38 PM
c69ss396's Avatar
What he said...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 7 Old 01-22-2014, 05:15 PM Thread Starter
Krug's Avatar
Quoted: 14 Post(s)
No the valves were not sunk
Krug is offline
post #5 of 7 Old 01-22-2014, 05:18 PM Thread Starter
Krug's Avatar
Quoted: 14 Post(s)
I just looked at the lifters that the shop pulled out they look fine to me, if the lifters look good should every think else(cam) be ok?
Krug is offline
post #6 of 7 Old 01-22-2014, 05:29 PM
c69ss396's Avatar
I'd send the heads out to someone who is worth a damn. The valves need to be "recessed" to match the amount milled from the head...
c69ss396 is offline
post #7 of 7 Old 01-22-2014, 05:35 PM Thread Starter
Krug's Avatar
Quoted: 14 Post(s)
I think Im just going to get remanufactured ones, this project has been going on for over three months, I just want to get some thing that will work and drive the darn thing.
My only concern was if there would be any thing wrong with any other components that would have been caused by the valve smacking the piston and bending the push rod multiple time.
I am also looking for reasonably priced remanufactured heads if any one has any suggestions as to where quality ones can be purchased.
Krug is offline
