Hard to start in the cold - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-22-2014, 02:44 PM Thread Starter
Have a 2003 f250 6.0 won't start when cold .but if truck is plugged in, truck will start great .i Have replaced glows plugs and wiring harness and GPCM . I Have tested the FICM and it tested good .it is not showing any codes . Is there something I am over looking or something I am not checking
Riggse is offline
post #2 of 15 Old 01-22-2014, 03:27 PM
c dog's Avatar
Does it crank and won't start or won't even crank? Batteries new or good?
c dog is offline
post #3 of 15 Old 01-22-2014, 05:52 PM
Quoted: 10 Post(s)
I have the same issue with my 04. If it's really cold out the glow plugs cycle but the truck won't turn over. If I plug the truck in it starts no issues
mike01844 is offline
post #4 of 15 Old 01-23-2014, 04:36 AM Thread Starter
Yes . Truck will crank and when it starts or if it starts blows white smoke out . This only happens in cold weather . If it is 50% or warmer it starts great no problems and yes batteries are new
Riggse is offline
post #5 of 15 Old 01-23-2014, 04:42 AM Thread Starter
Yes will crank but when it starts or if it starts blows white smoke out . This only happens in cold weather . If it 50% or warmer it starts great
Riggse is offline
post #6 of 15 Old 01-23-2014, 06:08 PM
what weight oil are you using sounds like you have some injector sticking if you are using 15w start using a full syn 5w with a couple bottles of rev x you probably will see a difference
budlight321 is offline
post #7 of 15 Old 01-24-2014, 06:15 AM Thread Starter
I am all ready using 5w full syn. For 4 years now . But I will add the rev. X thanks for your info.
Riggse is offline
post #8 of 15 Old 01-24-2014, 06:20 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
What kind of temps are you dealing with? You said you tested your ficm,what #'s were you seeing? Have you tested your batt's? How old are they?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 15 Old 01-24-2014, 06:27 AM Thread Starter
Anything below 45% and under .Yes tested FICM number was 48.7 . Batteries are 4 months old and tested good
Riggse is offline
post #10 of 15 Old 01-24-2014, 06:35 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
what was the ficm #'s once it started?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
