O6 f350 grinding when in 4wd - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-21-2014, 05:33 PM Thread Starter
Hey guys, I need some help.
I have an 06 f350 6.0, when I put in 4wh (manual hubs) and start driving I hear a horrible grinding noise from the driver side front wheel. Almost sounds like something is hitting the drive shaft. It only happens in 4wd and only when I start driving, goes away at 30 mph. I don't think it is a u joint or anything since it only happens in 4wd. Could it be the hub isn't locking? Could use any suggestions you have. Thanks guys
Dtruck6464 is offline
post #2 of 2 Old 01-21-2014, 05:53 PM
midnite rider's Avatar
Quoted: 285 Post(s)
sounds like a hub to me
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
Tags
4wd , grinding
