Another Head Gasket/Degas Cap Leak Thread... - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-21-2014, 01:25 PM Thread Starter
I didn't want to high jack anyone's thread so I am starting one for my truck.
156K Miles. Bullet Proof all but studs and HGs...
Been running Xtreme Street tune by I.D.
I noticed my degas cap spewing a few weeks back, topped off the coolant and replaced the cap with a Stant brand cap. I noted yesterday my EOT was getting higher than normal and I thought it may have to do with 4" TB exhaust I had just done the day or two before, but there was the coolant all over the degas again...
With the old cap I also had a whine at deceleration, the new cap seemed to fix that... But apparently I am still getting over pressure and spewing coolant from the cap...
So, after a few hours of reading stickies and searching under the hood, I think I have found the issue... Passenter side head looks to have been leaking for some time. There is yellowish gunk, but not real wet to touch.
I also have a failing IC pipe boot or something else is leaking oil on top of the motor. I noted the oil under the pan but chalked it to the glow plugs...
Here are the pics. Does this seem like I am headed in the right direction? HG's and studs are in the future for me...
In the mean time, truck is back to stock tune and will be monitoring like crazy...
TxOutlaw is offline
post #2 of 16 Old 01-21-2014, 01:27 PM Thread Starter
Pics of passenger side head
Another Head Gasket/Degas Cap Leak Thread...-imageuploadedbyag-free1390339613.503795.jpgAnother Head Gasket/Degas Cap Leak Thread...-imageuploadedbyag-free1390339624.623520.jpg
Pics if oil under IC tube boot
Another Head Gasket/Degas Cap Leak Thread...-imageuploadedbyag-free1390339658.157074.jpg
Thanks for any help!
TxOutlaw is offline
post #3 of 16 Old 01-21-2014, 01:31 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
It's hard to make out in the pic but head gaskets generally don't leak externally on these trucks.
dhanna6powerstroke is offline
post #4 of 16 Old 01-21-2014, 01:43 PM Thread Starter
Good to know. I don't see puddling under the truck. I don't have odd color in exhaust...
I guess next step is research getting a psi gauge on the system.
TxOutlaw is offline
post #5 of 16 Old 01-21-2014, 01:46 PM
Mod Newbie
Quoted: 20 Post(s)
Is it possibly leaking out of the heater hose where that valve is at and falling on top of the head and then running down?
post #6 of 16 Old 01-21-2014, 01:55 PM Thread Starter
What is the plug in the spot light in the first pic? That one has the same yellow crud around it. It that the heater hose?
TxOutlaw is offline
post #7 of 16 Old 01-21-2014, 01:57 PM
Mod Newbie
Quoted: 20 Post(s)
Yeah, that's the valve and heater hose. It's actually there to block coolant flow to the heater core when A/C is on max so coolant flows to or through that valve all the time.
post #8 of 16 Old 01-21-2014, 02:14 PM Thread Starter
Oh gotcha. Maybe pull and inspect/replace these guys? Flush the system? It was flushed about 30k miles ago, not sure what coolant is in it now.
TxOutlaw is offline
post #9 of 16 Old 01-21-2014, 06:08 PM
Mod Newbie
Quoted: 20 Post(s)
I'd get a pressure tester and pressurize the system and watch for it to leak.
post #10 of 16 Old 01-21-2014, 06:45 PM Thread Starter
I will see if a local parts store loans these testers out and go from there. Thanks!
TxOutlaw is offline
