ball joint replacement? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-20-2014, 07:10 PM Thread Starter
I'm thinking of changing out the ball joints on my 250. I had to change a tire tonight and just did the ol wiggle test and the passenger side was loose. I've got a shop with about every standard tool you could think of is there any "specialty tools" I might not have to complete the job. The other thing could anybody give me a COMPLETE parts list i would need to accomplish this task? Thanks
wingsandwalleyes is offline
post #2 of 3 Old 01-20-2014, 07:18 PM
DieselnDrums's Avatar
I never used any special tools other than a ball joint press. there really isn't a parts list other than having the ball joints to do this. but there is always some stuff you could do while you have everything apart, like you could replace you ABS cable, try and grease your wheel bearings, just be careful about the O-ring and the axle shaft seal.
06 f350, 6.0, 5 torqshift, egr delete, replaced oil cooler, SCT tuner, Head studs, MTW St 1 billet wheel, Custom tunes from GH.
DieselnDrums is offline
post #3 of 3 Old 01-23-2014, 03:24 AM
Gus_hauler's Avatar
When I first got my truck I found that the front right brake caliper has been locked up and had gotten so hot it ruined everything on that side. Of all the things I had to replace, the ball joints were without doubt the worst. Thankfully I had a friend's help in a shop that works on farm equipment, so we had every tool possible. The hardest part, that you would have at home would be pressing the ball joints out of the knuckle. We had a big shop press, and it took all it had to get them to pop out. Not to mention it was a pain orienting the knuckle just so we could get the right angle on the press. If you're going to try this job at home, I would definately take the knuckle somewhere to have the joints pressed out and in.
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
