truck wont start---codes
well no problems till now. ran truck about 200 miles last sat, engine light came on. tried to check it with xcal said no codes so i cleared them. ran fine home. wed tried to crank it to go to work, just bucked and jerked for a second then died. checked on scanner ( snap on- motis) code said po611- ficm- uo306-software iincompatable with ficm- po487- egr/tp control circuit. did research and decided to go ahead and change ficm. still no start and now code uo105 and still uo306 . still have warrenty but no converter on truck. dont know if ford will cover it now. has anyone run into this before? any help would be appreciated...............
You need to have all three modules reprogrammed (PCM/FICM/TCM) any time either is replaced. The ONLY tool capable of this is Ford's IDS laptop.
