Fuel pressure gauge help!! - Ford Powerstroke Diesel Forum
Old 09-24-2008, 04:43 PM
Trying to install a fuel pressure gauge and the instructions simply say " connect the fuel pressure sending unit to the fuel system.(preferably at the fuel rail)."
Uh, ok, where do I start? Any help is appreciated.
Thanks,
Dave
Old 09-24-2008, 04:48 PM
you are better off getting billet bowl cap..that way its already tapped for the 1/8 sender
Old 09-24-2008, 05:06 PM
Any other options for the sender that I was given with the gauge?
Old 09-24-2008, 05:10 PM
sorry i cant help you the 6.0s are unknown area for me, but where are you going to mount the gauge? I am going to get one, but im thinking of putting it outside infront of the windshield
Old 09-24-2008, 05:23 PM
Instructions say on the fuel rail and nothing else.
Old 09-24-2008, 07:34 PM
ive been told there is a access port on the bottom of the fuel bowl but its a different thread not a 1/8. I ran my gauge off my raptor pump and set it. its under the truck. I am gonna be putting one up top still outside the cab. probably on the cowl there, will most likely buy the billet cap or just try to tap the side of the fuel bowl itself.
Old 09-24-2008, 07:37 PM
yeah im putting the one on my 7.3 on the cowl. well I will actually end up with 2, one under the hood, it came with my RR but for some reason i cant talk anyone into riding under the hood at WOT so i can see what pressure is so hence the one on the cowl
Old 09-24-2008, 10:32 PM
Evan is correct, there is a plug in the bottom of the fuel bowl. You can adapt to with fittings or pickup one of these. 6.0L Fuel Pressure Adapter
