Codes pulled from my g/f 03 6.0 truck. . .what do they mean
P0603--Internal control mod kam error
P2285--Injector Control Pressure Sensor Circuit Low What do these codes mean and what do i have to do to fix them just had a superchips programmer on the truck which has ran fine for almost 10k miles and now these codes have came up. . .pulled them with the programmer any help would be appreciated. . . took the programmer off and cleared the codes and it still came back on the truck also has a hard time starting . . . My 7.3 sounds like it has a huge cam in it when it starts in freezing cold weather and her 03 6.0 does the same sounding thing even when it is like 50 degrees outside please help we dont want to drive around with the check engine light |
The first one means you have a programmer.
THe 2285 is the ICP sensor. I would replace it. But I would remove the programmer first, reset the codes, drive around, retest. No codes? The programmer is causing them., |
thanks a lot. . .i took out the programmer and the light went out 2 days later and has been out for a few drives now with no problems if it comes back on i will replace the ICP thanks for the reply
You may want to check closely at the back of the engine for oil leaks. 2003 model years ALWAYS blow out the ICP sensors. What ends up happening, is the oil blows through the sensor and destroys the sensor and electrical connector to it. The fix for this, is to replace the ICP sensor (Ford part number 3C3Z-9F838-EA) and the connector (Ford part number 5C3Z-12224-A).
well the dreaded light is back on again. . .guess it is time for a sensor change anyone have any good directions with some good pics on changing and ICP sensor time expected for the fix ? i already took it down and got it reflashed for the cold start problem but it still does it sometimes??
thanks for everyones help its a lot easier to ask a question on here rather than trying to search the net or ask a mechanic the question |
