Rear Tire Removal?? - Ford Powerstroke Diesel Forum
Old 09-08-2008, 11:31 AM
Rear Tire Removal??
Hey guys.. back tire will not come off the hub?? any tricks?? I have tryed everything I can think of including the beating method and nothing??
Old 09-08-2008, 11:48 AM
that has happened to me a few times.....its corrosion holding it on....get some WD-40 and a pry bar and a sledge.... I had it so bad once that I have to cook it off with a torch (I had been in salt water).... it usually happens when you don't rotate your tires enough....
Old 09-08-2008, 11:53 AM
Yea I usually get underneath the truck and kick them from the inside and it eventually knocks them off
Old 09-08-2008, 12:00 PM
Send a message via AIM to jhaddox
just get some pb plaster or wd-40 spray at it and start kickin. just to be safe id hit the rotor with brake parts cleaner to make sure you didnt over spray on them
Old 09-08-2008, 12:24 PM
jack the back end up and loosen all of the lugnuts a bit(but don't remove them ) run it up to about 30-40 and slam the brakes this usually works quite well
Old 09-08-2008, 12:28 PM
loosen lugs so their is room for weel to move let truck down leave some weight on jack and grab bumper and shake truck if that doesnt work spin wheel and repeat.
Old 09-08-2008, 12:45 PM
Loosen lugnuts a couple turns without jacking it up. Back up and hit brakes. When you here the wheel break loose ease it back to the jack.
Old 09-08-2008, 12:54 PM
why not stop and bring the jack to the truck....lol...
Old 09-08-2008, 01:43 PM
Nobody is suggesting that he take the lug nuts off first .
Seriously though, thanks for the tips. I rotate my tires every oil change (5000 miles) so I'm sure I'll encounter this problem sooner or later. Time to get the BFH out!
Old 09-08-2008, 01:49 PM
Used to do this with the old poly-cast wheels on the T-birds in the late seventies all the time. Sometimes you still had to hoist them and beat them until they bent. Couldn't put the heat to them because the plastic "mag" would melt. So loosen the nuts and drive them around the lot until the wheel breaks loose.
