Need sct help!! - Ford Powerstroke Diesel Forum
Old 09-07-2008, 11:06 AM
Need sct help!!
Im having issues getting the spartan file from my desktop to the tuner. i open the updater, i click transfer file, i chose the spartan file that i saved to my desk top and it says "failed to read data" what gives?
Old 09-07-2008, 11:44 AM
Send a message via Yahoo to 06ARMADILLO
I went through this same issue a while back. Open and close Live Load several times. Try loading the tune more than once. Keep in mind that you are dealing with computers, they are tempermental. Persistance was the key for me.
Old 09-07-2008, 11:56 AM
i keep trying, when my sct first comes on and gives all of the info, the 3rd line or so says "device locked". after it tells me "failed to read data" about 100 times it says "device could not be unlocked, try disconneecting and reconnecting" im still clueless
Old 09-07-2008, 11:57 AM
Rob Rob is offline
delete that file and download it again. make sure your firewall and virus protection is off only while you DL the tune. it may have been corrupted during transfer.
Old 09-07-2008, 12:05 PM
still giving the same message, it also gives me the same message when i try to retrieve the stock file "failed to read data"
Old 09-07-2008, 05:51 PM
follow walker. Turn off the firewall, the anti-virus etc. Plug your SCT in first, then fire up Live LOad. Make sure you unlock that thing. Several attempts may have to be made to connect the usb, restart LiveLoad etc. I had to even erase LiveLoad, then re-install it. Also delete all the spartan files you currently have. Make sure you are downloading for your specific model year. I had trouble with 1 or 2 for my specific year, and had to get the ones for multiple years. I also made a desktop folder labelled "tunes" to make finding my downloaded data easier to find. Additionally, ensure that you have installed all the appropriate drivers for your specific SCT, find them after downloading them and run them. After they are updated, restart your system.
Windows is a witch.
Old 09-07-2008, 06:35 PM
this maybe a little too indepth but how do i turn off all that stuff?
Old 09-07-2008, 06:44 PM
First find your anti-virus, it should be in your status bar on the bottom right if its running. Right click that baby. Should get an option to "disable" Say "YEPPER". Next, there are internet options if you are running Internet Explorer. Should be under "Settings" Go to "Security" Should be a listing for "Windows Firewall" turn that beeotch OFF. Then download the goodie bag to a NEW destination folder on your desktop. I like to label mine TUNES.
Old 09-07-2008, 06:45 PM
Where are you in GA?
Old 09-07-2008, 07:36 PM
i was in alpharetta but i moved to texas last week
