questions on headgasket failure???? - Ford Powerstroke Diesel Forum
Old 09-02-2008, 12:55 PM
Can head gasket failure cause coolant to leak under the truck?
I have to add a gallon of coolant every 2-3 weeks and I cant figure out were its going. Every once in a while it will leave a small spot under the drivers side front of the motor. I have a brand new water pump on it, EGR system including the cooler is completly deleted/removed from the truck.
It runs fine with no smoke of any color. I cant for the life of me figure out whats going on here.
Old 09-02-2008, 12:59 PM
I wanna go fast!!!
When the gaskets went out on my truck it would puke through the coolant bottle, and whistle under acceleration.
Old 09-02-2008, 01:01 PM
It doesnt puke any out of the bottle at all.
Also it doesnt run hot at all untill after it gets low on coolant.
Can the oil cooler leak coolant?
Old 09-02-2008, 01:26 PM
That's what mine would do exept when I would pull a heavy load, then it would puke out the bottle. Both heads were warped on mine, new heads, gaskets and some studs cured it.
Old 09-03-2008, 09:52 AM
I guess I will start saving now....
When I change the headgaskets, will I need to change all the O-rings on the injectors and ect...
Were is the best place to buy a Gasket kit?
Old 09-03-2008, 10:01 AM
<-Day Of Fail now SOLD
I think someone mentioned that Ford sales a kit that has all the gaskets o-rings ect. even has some stuff you don't need.
Old 09-03-2008, 10:13 AM
Or you could go see the boys at Trucks Unlimited and they will even put stud in and have it back to you in the same day.
Old 09-03-2008, 04:44 PM
Powerstroke Diesel Enthusiast
I'd buy a cooling system pressure tester (or take it to a shop and get them to pressurize it) and check for a leak. Its an invaluable tool especially when you own a six loafer, plus it helps you properly diagnose your issue.
Old 09-03-2008, 06:14 PM
Thats not a bad Idea. I do plan on studing it as soon as I get the money anyway though.
Powered sparkless, that sounds good but I bet it cost 2000 more dollars then I could it for and I cant afford that. I'm stuck with the doing it myself due to being poor
Old 09-03-2008, 06:33 PM
Rice Hunter
FOR SURE!!
