How to?? replace alternator? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-02-2008, 10:57 AM Thread Starter
The alternator looks easy to replace but what is the trick to loosening the belt?
mannastev is offline
post #2 of 7 Old 09-02-2008, 10:59 AM
International Threat
Marty's Avatar
maybe this will help
6.0 belt tensioner
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 7 Old 09-02-2008, 11:00 AM
GGOODMAN's Avatar
I did it redneck style. Sat on the bat. grabbed th belt pulled up and took it off the alt. Installed new alt. Pulled belt up enought to slip it back on the Alt.
this was on the truck below. What year is yours?
04' F250
4x4 cc Lariat
50k
4" lift 315's
Zoodad mod
Lead foot Disease (pump prices have nearly cured me)
GGOODMAN is offline
post #4 of 7 Old 09-02-2008, 11:06 AM
GoldieStroker944's Avatar
if it a 7.3 there is like a nut on the tensioner and you can put a wrench on there and pull it back which loosens the belt kind of a hassel if your by yourself tho
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
post #5 of 7 Old 09-02-2008, 11:06 AM
never mind i just seen its on the 6.0 thread sorry
2003 7.3L
Crew Cab Short box
Lariat
T.S 6pos
AFE stage 1
Foil delete
Sirius sat radio
post #6 of 7 Old 09-02-2008, 11:39 AM
scotty2280's Avatar
ditto its the easyist and can be done in about 15 min start to finish!
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #7 of 7 Old 10-17-2008, 11:45 AM
Tacomarunner's Avatar
Sounds easy... What about for a dual atlternator set up. The top one can be changed as described, but the lower one looks a bit more involved.
Thanks
Russell
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
