03 oil leaking from the back of motor - Ford Powerstroke Diesel Forum
Old 08-23-2008, 06:57 PM
Pulled in to the house last night and instantly found oil dripping from under the trans / motor . First thought was rear main but looks like its coming from higher up .. Anybody know where this might be coming from? Help
Old 08-23-2008, 07:05 PM
aluminum tubing engineer
...have you done the ccv mod yet?
Old 08-23-2008, 07:10 PM
no what is the ccv mod
Old 08-23-2008, 07:20 PM
It could be the bedplate seal. It is a common issue with the 6.0, but it is not a cheap or easy fix. Good luck.
Old 08-23-2008, 08:08 PM
I think its coming from up higher then the bedplate seal. It looks like its coming from the back of the head or the back of the turbo area . I started to pull the turbo but couldnt get the rear turbo mounting bolt off ..
Old 08-23-2008, 08:24 PM
More than likely it's your ICP sensor leaking - I've replaced many on the 03'-04' 6.0l.
Old 08-23-2008, 09:37 PM
Yup, its probably your ICP sensor, no need to pull your turbo to replace it.
