Coolant loss????? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-22-2008, 02:55 PM Thread Starter
GnFnRs's Avatar
Coolant loss?????
every 2 weeks i have to add a gal. of coolant to my excursion.i took it to the shop, they told me it was 90% headgasket failure. so i bought the arp studs and dropped it off at the dealer. i have 3 weeks of warranty left. well they call me today and tell me that they have tested everything, including egr cooler HGs and all and can't find anything whatsoever.
now i have a set of studs and no i dea where my leak is. any idea's?
the studs are for sale in the for sale section, need to recoup some cash till i actually need them..
2003 excursion
6.0 psd baby!!
100% stock for now.
clean oasis report. not a single item till now.
76,000 miles when i bought it.
needed 2 injectors, y pipe, lower rad hose, egr valve.
now has 82,000 miles.
lovin every min of it
GnFnRs is offline
post #2 of 10 Old 08-22-2008, 03:08 PM
scotty2280's Avatar
they are probably just trying to run your warranty out go to another dealer asap
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #3 of 10 Old 08-25-2008, 12:22 PM
Are you in Baton Rouge? If so, take it to Robinson Brothers. They will fix it and fix it right. Your gaskets are blown. Don't let them trick you into running it out of warranty.
BTW - GO TIGERS!
cajun1963 is offline
post #4 of 10 Old 08-25-2008, 12:24 PM
<-Day Of Fail now SOLD
POWERED SPARKLESS's Avatar
MY THOUGHTS EXACTLY
With that much coolant loss you deffently have a problem.
Tyler T
Sold 2 April 2011
To some lucky SOB
2004 6.0 CC FX4 Lariat
It had all the right things missing or added
Originally Posted by DunesRunner08 View Post
IF YOU DO NOT STAND BEHIND OUR TROOPS....FEEL FREE TO STAND IN FRONT OF THEM!!!!!
POWERED SPARKLESS is offline
post #5 of 10 Old 08-25-2008, 12:28 PM
BTW, keep the studs, your going to need them. Once you get them in, the 6.0 will be fine for many more miles.
post #6 of 10 Old 08-25-2008, 03:03 PM Thread Starter
GnFnRs's Avatar
i'll take it by there this week. warr. runs out on the 3 or 5th of next month i forgot lol. if they won't do it under warr. i'll sell the studs and just re-buy them later if i need them. i was told when i bought it that if it made it to 76,000 miles with no problems that it may be a good motor and never need anything. also it was really weak in 1 st gear when cold. they re flashed the pcm and turbo....now it won't get out of it's own way in first. it's actually worse
2003 excursion
6.0 psd baby!!
100% stock for now.
GnFnRs is offline
post #7 of 10 Old 08-25-2008, 03:07 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Find another dealer if you are loosing that much coolant you have issues
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 10 Old 08-25-2008, 03:45 PM Thread Starter
GnFnRs's Avatar
BTW - GO TIGERS!
called robinson bro's they will only do stock. no studs at all unless customer is paying for the job. and they want $2500+parts.
so i am gonna sell the studs to get out of a slight bind i am in at the moment and just get more later if i need them...
2003 excursion
6.0 psd baby!!
100% stock for now.
GnFnRs is offline
post #9 of 10 Old 08-26-2008, 06:07 AM
Did you talk to Mark? That is the probably the standard answer you would get from him. You did say that you never programed the truck too right? I know the service Manager real well and I can help you with this. They will do the studs and they won't charge you anything. Send me a private message and I will call him for you.
post #10 of 10 Old 08-26-2008, 01:58 PM Thread Starter
GnFnRs's Avatar
yea i talked to mark, he said that he had to go through his service manager and that there was noway that they could do it as close as my warranty is to going out.
cajun1963 you have pm...
2003 excursion
6.0 psd baby!!
100% stock for now.
GnFnRs is offline
