05 bad mileage, runs rough - Ford Powerstroke Diesel Forum
Old 08-20-2008, 11:33 AM
I have a friends 05 6.0 that is getting bad mileage and runs rough for a minute after staring. It has 3 codes 0261, 0284, and 0611. Any ideas would be great. Thanks, Chad.
Old 08-20-2008, 12:07 PM
Run an injector buzz test. most likely you have a bad injector or your ficm needs to be reflashed. The ficm may also be bad. and run a cylinder cylinder contribution test also.
Old 08-20-2008, 01:22 PM
I ran the injector buzz test and it they tested good. I have an OTC scanner that will run a self run a KOEO self test. It will start to run the test but gets a 0261 code( Inj. circuit low cyl. 1) and stops the test. Any other ideas? Thanks for the input.
Old 08-20-2008, 02:18 PM
Check the harness to each injector, making sure there are no shorts and the are ok. Then ohm out the injector, and do you have a wiring diagram? If so check powers and grounds to ficm. If everything checks out you most likely have a bad ficm. Does the truck have the latest reflash? Is there a clicking sound after shut down? If not get it reflashed.
