HELP DTC CODE PO611 - Ford Powerstroke Diesel Forum
Old 08-17-2008, 10:17 AM
HELP DTC CODE PO611
Could anybody help?have this code now after having the truck for over a year,showing on the scanner that it is injector control module,performance....
does this mean that the module is going bad,or the injector pump is going bad.
it also threw 8 other codes all of them are injectors,PO261,po264,po267,po670,po273,po276,po27 9,po282.
all of these codes are injectors 1,2,3,4,5,6,7,8 injector circuit,low.Does this mean injector pressure is low?is the pump going bad?
please help
Clay
by the way the truck is a 2004 F350 cc/sb 6.0,the truck has 136000 kms on it and i have only ever used the 60 hp tune(predator).Are any of these parts under warranty?
Thanks for all the help you can give.
I am going to put the truck back to stock and see if the codes go away.
Old 08-17-2008, 10:44 AM
yes,it should be under warranty.i would take everything performance off the truck first.
Old 08-17-2008, 05:47 PM
You'll be close on warranty. If your FICM goes out then you'll get injector codes like that. Check to make sure one of the connectors didn't come out. The FICM is located on top of the driver's side valve cover.
Old 08-18-2008, 05:49 AM
Slacker
Feedback Score: 4 reviews
As Tim says, it is likely the FICM and would be covered under warranty. Since you have two connectors from FICM to two banks of injectors, it isn't likely that both connectors have come loose, but you might want to check it anyway. I would pull the tuner and see if your check engine light comes back. PS. Mine has been doing this off and on for the past couple of months, but won't set the CEL in stock form.
Old 08-20-2008, 09:49 AM
THANKS FOR THE ADVISE,I PUT THE TRUCK BACK TO STOCK AND THE CODES WENT AWAY.I THINK THAT WHEN I DISCONNECTED THE BATTERIES WHEN WELDING ON THE TRUCK IT MAY HAVE SET THE CODES...
I WILL REINSTALL THE TUNE AND SEE WHAT HAPPENS AGAIN....
THANKS AGAIN
CLAY
