Starting - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-14-2013, 06:16 AM Thread Starter
Starting
I have alot of problems with batteries constantly going dead on me, i have alot of stuff running on my truck and i was wondering would it be a bad idea to add 1 or two more batteries to my tuck. Any body have any ideas?
Sent from AutoGuide.com App
baseballstr1 is offline
post #2 of 7 Old 11-14-2013, 07:49 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
What do you mean you have alot of stuff running on your truck? Like when the key is off? And adding 1 or 2 more batteries will overtax your already weak alternator and/or batteries. Theres obviously a problem somewhere that needs to be fixed.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 7 Old 11-14-2013, 07:54 AM Thread Starter
I have KC lights, fender well lights, my subs, and train horn compressor hooked to my batteries. I have the after market mean green alternator that i just put on my truck a couple of months ago and since its gotten colder i have had to jump my truck of twice. Everything goes off when i cut my truck off
post #4 of 7 Old 11-14-2013, 07:54 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 571 Post(s)
Garage
How many days does it take for batteries to go dead.
You may have a drain on the battery.
I would track down the problem before I installed more batteries.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 7 Old 11-14-2013, 07:55 AM
Chapter Director
Quoted: 5 Post(s)
Yes i agree you have a drain, none of those things should matter when the truck is off. Maybe something is leaking through a switch or something
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 7 Old 11-14-2013, 07:58 AM Thread Starter
I'll check all this, thanks
post #7 of 7 Old 11-14-2013, 11:27 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
I'd take the batteries, have them load tested separately, have the charging system tested at the same time, and run a test for parasitic draw.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
