Uo155 code any info would be great - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-11-2013, 03:59 PM Thread Starter
I've been having a hell of a time with my truck this week, it first started I would loose my whole gauge cluster as well as the windows and radio and sun roof, but the truck would run fine as well as would not throw any codes, then I started to loose gauges,windows,radio, as well as a high in gear idle and it felt like the truck was starting off in 3rd gear. When the gauges come back on all is well, so finally it through the Uo155 code witch is lost communication with instrument cluster, so what to do now? Change the cluster or is it a bad wire? Any advice would be greatly appreciated
strokin629 is offline
post #2 of 6 Old 11-11-2013, 05:01 PM
Check fuses and relay also check for loose plugin to instrument cluster.
You could also have a instrument cluster module going out.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 11-11-2013, 05:14 PM Thread Starter
I checked everything 3x's. is the cluster control module part of the cluster or separate and is that common?
post #4 of 6 Old 11-11-2013, 05:54 PM
It depends on the year 03-04 the module was mounted seperate. It was mounted to the back side of the inside fusebox. The cluster itself wasrepairable by a novice.
In 05 the cluster was physically able to be repaired but Ford would not sell just the parts you had to order the whole cluster.
In 06 the cluster could not be taken apart was digital and solidstate. Module is internal to the cluster and is not serviceable.
post #5 of 6 Old 11-11-2013, 06:27 PM Thread Starter
Awesome information!! Thanks for your help I think this helped me narrow it down quite a bit I'm going to order a cluster throw it in and I will post back and let you know how it goes
post #6 of 6 Old 11-15-2013, 01:32 PM Thread Starter
Well changed the cluster and the truck runs perfect now! Thanks for the help
